Fixed it for youn smikle wrote:Rosberg says there is more to come from the exhaust upgrade.
[youtube]http://www.youtube.com/watch?v=JMlscEoKd_k[/youtube]
Brawn also revealed that Mercedes will test its so-nicknamed "DRD" concept in free practice in Japan in two weeks.
"We could use it in practice and at the moment I think it’s very unlikely that we will see it in the race just yet," he said.
I was actually asking Mantikos how he came to the conclusion that the rear wing is "good" and only the diffuser needs changing. With a mediocre(and sometimes downright poor) car, how does one come to the conclusion that the rear wing specifically is "pretty good", especially considering this car is widely though(at F1T anyways) to lack rear downforce?Adamski wrote:Look at the top team's wings, those are much more complicated and curved, especially at the lower regions. Of course the more it is complicated the more harder to set it up and make the best of it, but it is also a sign that you are working on it and trying to make it better.Pierce89 wrote:How do you come to this conclusion? None of us know quite how good or bad any individual wing is.mantikos wrote: Diffuser maybe, rear wing is actually pretty good
Merc do not fine tune it although they should do it as they are changing the car's other parts which means the airflow changed more or less around the back of the car.
I'm very confident we will see an upgraded rear wing from Merc in the next couple of races and as I read the new diffuser now confirmed.
Pierce89 wrote:[quote="AdamskiI was actually asking Mantikos how he came to the conclusion that the rear wing is "good" and only the diffuser needs changing. With a mediocre(and sometimes downright poor) car, how does one come to the conclusion that the rear wing specifically is "pretty good", especially considering this car is widely though(at F1T anyways) to lack rear downforce?
@adamski I get your line of thought but complexity doesn't necessarily mean quality
Edit: Because of the "three quote rule", I had to edit four times to get the quotes right. I hate forum quoting, but whenever I fail to quote,invariably, the wrong person responds.
I never said it wasn't a good wing. I was just pointing to the problems of claiming a single part of a mediocre car is "good". Realistically, we only know that they thought the exhaust wasn't up to snuff, but claiming the rear wing is good, while the diffuser is bad is overreaching. You have no facts to back it up. I'm not saying you're wrong, simply because none of us have enough info to really analyze the situation.mantikos wrote:Pierce89 wrote:[quote="AdamskiI was actually asking Mantikos how he came to the conclusion that the rear wing is "good" and only the diffuser needs changing. With a mediocre(and sometimes downright poor) car, how does one come to the conclusion that the rear wing specifically is "pretty good", especially considering this car is widely though(at F1T anyways) to lack rear downforce?
1. Because I have never heard anything negative about the rear wing anywhere
2. Because the rear wing seems to have as much detail as other wings on the grid
3. Because I can ask you what makes you think its is not a good wing, point it out on a pic
Rear grip is not solely a rear wing's job the lack of rear downforce comes from the diffuser being not as good as the rest...
Mantikos, I disagree with you. As I said for me the Merc rear wing is too simple. As you mentioned it has as much detail as others in the field. Well, it depends on what you call details. Yes, it was a well designed and well engineered wing with nice details when they debuted it last year on the W02. But how do they think it is still working as perfect on a new car?mantikos wrote:Pierce89 wrote:[quote="AdamskiI was actually asking Mantikos how he came to the conclusion that the rear wing is "good" and only the diffuser needs changing. With a mediocre(and sometimes downright poor) car, how does one come to the conclusion that the rear wing specifically is "pretty good", especially considering this car is widely though(at F1T anyways) to lack rear downforce?
Who said the wing was deficient? I'm saying we can't make those judgements from our position.FoxHound wrote:Even if you had the required data, how would you know the W03 wing was deficient to other cars in terms of down force?
Adamski wrote:I think only the diffuser and the rear wing is still too simple compared to the top teams.
Mercedes introduced its version of the Coander exhaust, as pioneered pre-season by Ferrari, McLaren, Sauber and Red Bull. It uses the Coander effect to take the exhaust flow down over the rear brake ducts (1) and around the side of the diffuser, helping to aerodynamically seal that diffuser by reducing leakage from the gap between it and the track. The exhaust exits into an unusual square-sided body cut-out. There are small vortex generators (2) ahead of the rear tyre,
fashioned in aluminium. There was also a twisted-cascade outboard flap on the front-wing endplate.
GARY Anderson: This exhaust layout is more like Ferrari’s than McLaren’s, in that the exhaust bodywork housing itself is bulkier and higher up,but allows more of the Coke-bottle profile of the lower body to be retained. Where it differs from any of them is in having a square-edged outlet through which the exhaust pokes – and the underside of that outlet, where it meets with the Coke-bottle lower body, actually goes to a blade. It’s a tidy, neat solution. However, the exhaust plume through a circle isn’t a constant flow, but fast pulses – and this causes that plume to rotate. When you then enclose the pipe in a square-edged section like this the plume can no longer rotate – and that takes energy out of it. So I’d doubt if the effect is as powerful as it could be. The Mercedes has perhaps the most intricate and aerodynamically sophisticated rear brake ducts of any of this season’s cars, with a sliding skirt connecting them to the bodywork and a shape that underneath turns and twists around the tyre. They will be very powerful anyway and it could be that adding exhaust flow to them won’t dramatically multiply the effect. The improvised vortex generators will just be helping to divert more energy into that part of the floor.
