ringo wrote:Those sources are sensationalists. Until we hear one of the engine makers give a figure, then we have a good source.
Look on any turbo 1.6 engine out there on the street, and see if they are going to make over 750hp on 100kg/hr of fuel.
As i said blame it on the fuel rate.
I'm not saying i'm correct, but i have a foundation. I'm just going to stick with it and see what happens.
Not sure how valid this comparison will be but I can add some known numbers to the discussion.
Not quite apples to apples, but WTH. My 1.8 is currently making 470 at the wheels (I estimate almost 550 at the flywheel) with 1000 cc/min (about 44kg/hr) injectors at about 90% duty cycle. I realize I have more displacement, but I'm not using direct injection (only about 70 psi at full boost vs 500 psi) and only reving to just over 8000. This is a Honda engine in a car not originally designed for FI running on US 93 octane. Not sure how that compares to the fuel the F1 teams will be running but I would bet it is inferior.
Just looking at hp/L that comes out to 305 at the flywheel. If we have the same efficiency in a 1.6 that would work out to just under 490 at the flywheel. I realize this is devoid of calculations and making
a lot of assumptions but
I can believe 600-650 with 100kg/hr based on this.
I also want to add that I feel I have to be missing something somewhere. It can't be that easy can it? Please feel free to pick this apart. I want to learn all I can.
Noet: Edited power (bolded) was a typo was thinking 600 but wrote 700...
