Ferrari F2012
McMrocks
McMrocks
32
Re: Ferrari F2012
i think the slots in the fw reduce the downforce, right?
but it reduces stalling
edit: very small and simple end plates
amouzouris
105
Re: Ferrari F2012
McMrocks wrote:i think the slots in the fw reduce the downforce, right?
yes...u r right on that...it will reduce peak downforce but make the wing less likely to stall...that's why in monaco we see cars getting rid of most of the slots in search for more downforce that monaco requires!
Nando
Nando
Re: Ferrari F2012
amouzouris wrote:it will create downforce...its like the leading edge of the rear wing
edit: it would create lift if it was alone there without the rest of the wing behind it...i hope u get what i mean
Ok great so that part will indeed create lift but due to the whole wing that small percentage of lift will be offset by the downforce percentage.
raymondu999
Re: Ferrari F2012
It's a synergistic effect I think. On its own that small element will create lift. On its own the parts behind it will create downforce. But add them together as such and you'll have more downforce than you'd have with the parts behind it will, alone.
失败者找理由,成功者找方法
McMrocks
McMrocks
32
Re: Ferrari F2012
i guess that the guys from ferrari know what they do. i think you dont need a wing with much downforce but with much(many?) stalling
MIKEY_!
Re: Ferrari F2012
Why are they using a heat gun (I think that's what this is :wtf: )on the suspension bits??? I can't be that cold in Mugello can it???
Anyway I have been thinking that Ferrari might consider lowering and extending the Acer ducts to the floor rather than removing them. That creates a bridge like the old RB8 sidepods but with more volume underneath so they would work better.
Nando
Nando
Re: Ferrari F2012
McMrocks wrote:i guess that the guys from ferrari know what they do. i think you dont need a wing with much downforce but with much(many?) stalling
There´s most definitely a purpose for the design. Possibly to create vortex?
Or guide the air in a more focused way to the outside of wheel?
italian
italian
Re: Ferrari F2012
Autosprint article about new Ferrari exhaust http://www.auto.it/autosprint/formula_1 ... i+scarichi Guys it's in Italian!
"Two things are infinite: the universe and human stupidity, but about the universe I still have some doubts." Albert Einstein
Daniele M
Re: Ferrari F2012
MIKEY_! wrote:Image
Maybe some water went in that place and they need to remove it.
About the cold, today is not hot in italy, at mugello there should be 15-17°C.
Autosprint.it says that the new exhausts points downward, but at the moment they are causing some problems.
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F2012
Daniele M wrote: Maybe some water went in that place and they need to remove it.
It doesn't say the exhaust are specifically the problem. It says they're pointing down/exhaust going down and mechanics are looking on the floor. It just says problems. They allude to the fact it may be causing problems. may be. :)
enz0
enz0
Re: Ferrari F2012
New exhausts might be burning the floor or the rear suspension
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F2012
Very weird because this exhaust is illegal
via @antonioboselli
italian
italian
Re: Ferrari F2012
Regarding the Alonso's stop: he was asked to stop the car to avoid damages.
elFranZ
Re: Ferrari F2012
Crucial_Xtreme wrote:Very weird because this exhaust is illegal
[i/mg]https://p.twimg.com/ArzP9gJCIAAZGMg.jpg[/img]
via @antonioboselli
The photos you posted earlier clearly show a different angle. Here the exhaust is pointing directly to the floor... Couldn't it be just temporally disassembled?
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F2012
via @antonioboselli
It is testing. Maybe they are testing how much heat the floor can withstand.
