Mercedes AMG F1 W03
Red Schneider
Red Schneider
Re: Mercedes AMG F1 W03
ForMuLaOne wrote:Quite remarkable that autosport journalists are unable to spell coanda right...
That's the just the British accent - Senner, Coander, etc. ;-)
Cocles
And don't forget our current world champion... V'tell.
Huntresa
Huntresa
Coriander effect clearly :P
Coefficient
Coefficient
Indeed, takes a long Thyme to fully understand the concept and Mercedes were heeding some Sage advice in being patient to introduce the new exhausts.
aral
aral
26
Or even the collander effect, with all the holes?
beelsebob
beelsebob
85
Wasn't that banned when RedBull used it on their break ducts?
:D
FoxHound
55
If they have a flexing collander, wouldn't it be possible to slice coriander to effect the break ducks given a smoother flow of the wings? You wouldn't even require wind shear testing for the ducks!
JET set
beelsebob
beelsebob
85
At this point, I suddenly feel the need to bring up base plates of prefamulated amulite, and hydrocoptic marzleplanes.
First time I see the back of the nosecone (with the DDRS pipes).
ak21_rao
ak21_rao
DDRS is supposed to have 2 pipes but i see only 1 here.
They've brought two different rear wings.
Raptor22
Raptor22
26
ak21_rao wrote:DDRS is supposed to have 2 pipes but i see only 1 here.
You're not looking closely enough. see the notch in the left side of the nose cone, just inboard is the left hand side pipe connector.
Hangaku
beelsebob wrote:At this point, I suddenly feel the need to bring up base plates of prefamulated amulite, and hydrocoptic marzleplanes.
Need to ensure the deedieframulator doesn't knock against the fluff-fluff valve...
Yer.
Timstr
Timstr
Some developments(?) and pressure gauges on the floor.
hopefully they can turn their conundrum effect exhaust into visible laptime reduction effects this time...
