[ 2020 ] Aston Martin RedBull Racing F1 Team - Honda
Noetiepoerker26
Re: [ 2020 ] Aston Martin RedBull Racing F1 Team - Honda
Jaisonas wrote:
15 Nov 2020, 15:06
Ah yes, a Honda Certified™️ wet start. They still havent sorted that out...
Looked like Albon's start was indeed (almolst) just as bad as Verstappen's
Two stroke: a little more than half the power, twice as often.
velizare
velizare
Noetiepoerker26 wrote:
15 Nov 2020, 15:11
Jaisonas wrote:
15 Nov 2020, 15:06
or he just was told to not uphold verstappen at all.
Fulcrum
Fulcrum
Another example of why Albon shouldn't be driving for Red Bull next year.
Sieper
73
Just read that they had the complete wrong frontwing setting. Off by 7 degrees due to a software glitch apparently? That is massive. No wonder Max complained about the front wheel grip, especially on the inters. I already saw a handfull engineers busy checking the wing with measuring tools (and looking quite confused) during one of the FPs (I think it was).
GhostF1
GhostF1
110
Fulcrum wrote:
15 Nov 2020, 15:20
What? This was probably a standout performance for Alex this year.. his only major mistake came from absolutely ruined tyres while the track was still wet. His pace was fantastic during the race and general car control was among some of the best.
The result didn't come but he drove superbly in these conditions, even performing a fantastic overtake or two. Strategy and tyre life timing lost him a podium at least. Lewis is damn lucky his inters wore down to essentially slicks at the time they did.. perfect as the track dried just enough, any earlier (ala Alex's) and he'd of felt he would of needed to pit.
zibby43
zibby43
GhostF1 wrote:
16 Nov 2020, 02:12
Lewis kind of made his own luck by making those inters last longer than anyone else could in the changing conditions.
Albon had one of his best weekends pace-wise . . . although the results don’t show it. Kind of mixed emotions again at Red Bull, as Albon was looking the favorite for victory until his mistake.
velizare
velizare
GhostF1 wrote:
16 Nov 2020, 02:12
Fulcrum wrote:
15 Nov 2020, 15:20
too little, too late. i suspect things are settled by now. and perez delivered the results albon didn't managed.
Sieper wrote:
15 Nov 2020, 18:44
"Everything went wrong basically," he [Max] said. "It turned out that the adjustment of my front wing was completely wrong.
"On one side we were seven degrees short of what should have been our front wing set-up. That is quite a lot really.
"Normally you adjust one degree here or there, or something like that. But seven degrees, that is a lot. So what can you do as a driver? Almost nothing works as a result of that."
https://www.autosport.com/f1/news/15359 ... -in-turkey
Revs84
Revs84
16 Nov 2020, 18:22
Sieper wrote:
15 Nov 2020, 18:44
Like someone commenting under the motorsport.com article, I was also taking his comments with a pinch of salt, thinking, how much could the difference really have been? Until I saw the image :wtf:
There was a huge difference! Anyone knows if under any circumstance such a huge difference between left and right makes sense, or is this genuinely a mistake?
Big Tea
99
Revs84 wrote:
16 Nov 2020, 18:28
16 Nov 2020, 18:22
Sieper wrote:
15 Nov 2020, 18:44
https://cdn-1.motorsport.com/images/amp ... racing.jpg
Is that a genuine 'stable' image or has the car just dropped off the curb there and there is osculation?
Surely Max would have felt a problem with that amount of difference
Sieper
73
Big Tea wrote:
16 Nov 2020, 18:46
Revs84 wrote:
16 Nov 2020, 18:28
And he did. He was on the radio all weekend about understeer, unable to follow the McLarens, no grip on steer in. Etc. Etc. Plus the whole crew incl Monaghan were in his box with measuring tools before Q3 started. Looking dumbfound. Only on the full wets he was able to put the car where he wanted. Still. Somehow. This race hurts so much, it could have been an incredible win, he was so fast on full wets. :( :(
Revs84 wrote:
16 Nov 2020, 18:28
16 Nov 2020, 18:22
Sieper wrote:
15 Nov 2020, 18:44
Think the lighting in that picture is gonna make it look worse than it is. Plus, the side the picture is taken from will always look flatter.
Revs84
Revs84
diffuser wrote:
16 Nov 2020, 19:08
Revs84 wrote:
16 Nov 2020, 18:28
https://cdn-1.motorsport.com/images/mgl ... cing-1.jpg
It depends on which lap the photos were taken as well I guess. I don't remember which pit stop it was, but one of the flaps (I believe the right) was adjusted.
etusch
131
GhostF1 wrote:
16 Nov 2020, 02:12
Fulcrum wrote:
15 Nov 2020, 15:20
I also think that Albon raced well until he declared his tyre gone. I think Redbull should change his tyres as soon as his performance started to fall. It was a strategic fault and if it didn't happen Albon were not spin then who knew what would happen
Fulcrum wrote:
15 Nov 2020, 15:20
You know, you can agree or disagree with Fulcrum but voting him down just cause you don't like what he says is ...., I don't know filling the blank.
