Red Bull RB8 Renault
McMrocks
McMrocks
32
Re: Red Bull RB8 Renault
allstaruk08 wrote:Image
maybe i'm a bit late but is there a hole in the main element next to the endplatte. or is there only a bit colour missing.
astracrazy
astracrazy
31
There is somethine above the Red Bull on the Red Bull mobile logo, you can see the way the flow viz has run along it
boson
boson
its just the top edge of the sticker, looking back further in the thread you can see the edges of some of the others.
EDIT here it is again, you can see it clear as day here:
DDRS ducting and the RB mobile seems a sticker
Very good article by Gary Anderson.
http://www.bbc.co.uk/sport/0/formula1/20118852
What is the letterbox shaped holes that he is talking about though?
Cay man
Cay man
n smikle wrote:Very good article by Gary Anderson.
Anderson says: "The second problem is that when the car goes closer to the ground, as it does at higher speed with downforce acting upon it, a diffuser that works at high ride-height will stall earlier because the airflow cannot stay attached as the air pressure under the car decreases."
So someone can think that they can do this with an hydraulic system...
They have once again found red bulls secret? For like the 50th time since 2009...
aral
aral
26
wesley123 wrote:They have once again found red bulls secret? For like the 50th time since 2009...
The real secret is..............the driver.....Seb!
techF1LES
176
Hmm strange that he calls them letterbox.
munudeges
munudeges
-14
Cay man wrote:So someone can think that they can do this with an hydraulic system...
If they were doing that they would have solved their problems long before now. Seriously, other teams have had their chances and blown them. Searching for some crumb of comfort that Red Bull have got to the front via unequal means won't help.
jz11
jz11
19
n smikle wrote:Hmm strange that he calls them letterbox.
I agree, look like VHS tape recorder slots to me... :D
Huntresa
Huntresa
Which also looks like surprise a letterbox hole.
Nando
Nando
Bingo ;)
http://www.freefoto.com/images/04/27/04 ... ox_web.jpg
Owen.C93
Owen.C93
177
They haven't blown straight into the starter motor hole for a few months now anyway. All the air going into the ducts just goes into the hot air outlet around the gearbox while leaving the starter motor hole in the open like other teams.
