Toro Rosso STR7 Ferrari
aral
aral
26
Re: Toro Rosso STR7 Ferrari
Note that there are two different versions of this new monkey seat. One has straight edges and is closed off at the rear. The other has scalloped uprights, and is open at rear. Further, the revised monkey seat (both versions) uses ducted air from the engine cover, whilst when running the original monkey seat, there is no outlet from the engine cover.
so, it may be just experimenting with normal flow from the engine cover, maybe trying to divert engine air to the underside of the rear wing?
Forza
238
They've experimented with different "monkey seats" and cooling outlets since the pre-season tests. The one that they are using recently came in at Monaco and they've used it with both engine bodyworks (with and without cooling exit) depending on cooling requirements. These are some of combinations used before
Forza
238
US GP - Friday Free practice
techF1LES
176
For those who can speak Japanese... maybe there is something interesting about STR7 cockpit (maybe someone could translate?)...
Source: F1 Sokuho
scarbs
scarbs
393
my guess...
1: Nitrogen bottle for engine pneumatic valve return (PVRS)
2: Not sure (might just be a switch panel or electronic junction box)
3: Driver drinks bottle
4: Riedl driver radio
5: Rapid Brake bias adjuster
Isn't a little bit dangerous for no.1 to be in the cockpit, besides the driver, or is it a common placement? They have the fuel cell on their back too, but this is much closer.
scarbs
scarbs
393
The nitrogen bottle is commonly placed in the cockpit, Renault moved it to the sidepod with explosive consequences for heidfeld
timbo
timbo
111
scarbs wrote:The nitrogen bottle is commonly placed in the cockpit, Renault moved it to the sidepod with explosive consequences for heidfeld
Isn't it placed near the radiator on Ferrari?
aral
aral
26
Isn't nitrogen an inert gas? So presumably if it exploded on any car, it would be due to failure of the canister. Therefore, it would be far more dangerous to have it sited in the cockpit, than under the rear bodywork.
beelsebob
beelsebob
85
The issue was not moving the nitrogen bottle, it was moving the exhasts. The exhausts made the nitrogen bottle very hot, and indeed, made the bottle itself fail.
hardingfv32
hardingfv32
Practically speaking: If a bottle in the cockpit can be damaged in an accident, I think it safe to assume that the driver is not going to survive the level impact to reach the bottle.
Brian
aral
aral
26
[quote="hardingfv32"]Practically speaking: If a bottle in the cockpit can be damaged in an accident, I think it safe to assume that the driver is not going to survive the level impact to reach the bottle.
Brian[/quote}
I could see several ways that a bottle in the cockpit could be damaged in a crash, yet the driver survive.
Number 1 is the drinks bottle. The other lines are there to pressure the drinks bottle.
Those lines are not compressed air lines, which if made of plastic would have different types of connectors. And would never be free floating like that. Just my deduction.
wasnt the drinks bottle somewhere behind the seat? at least in a position that it was hidden
Lycoming
Lycoming
106
The drinks bottle isn't pressurized, its a windshield wiper motor that drives it, or something to that effect, at least at mclaren it is.
I also find it unusual that they would place the nitrogen bottle in the cockpit like that. FSAE requires pressurized systems like that to be protected by the chassis, but it can't be in the driver's cockpit.
