Mercedes W15
Unc1eM0nty
Re: Mercedes W15
28 Feb 2024, 19:45
Haven't seen other teams running up to that limit quite as much as Merc. If they had good correlation with as they claim I don't understand why they would need to do so much limit testing at testing compared to other teams
Its the first time they've drove a brand new car, why wouldn't they push to the absolute limit.
That would be part proving correlation surely
Formula 1 fan
Formula 1 fan
-2
Re: Mercedes W15
Does anyone know are there any visible differences on the car today compared to the car from the tests?
Luscion
Luscion
108
Re: Mercedes W15
Formula 1 fan wrote:
28 Feb 2024, 22:11
Mattchu a page back points out the difference, looks like the back of the sidepod has changed, and the stay is now vertical instead of at an angle
Mattchu wrote:
28 Feb 2024, 21:07
Looks like Merc have changed something at the back. This could just be fading eyes/the light/the angle/the stay not properly attached yet, but it looks like there`s now an opening at the back of the ramp, also the stay isn`t on an angle but goes straight up...
https://i.postimg.cc/hG0WfJxS/st.png
Formula 1 fan
Formula 1 fan
-2
Re: Mercedes W15
Luscion wrote:
28 Feb 2024, 22:20
28 Feb 2024, 22:11
Mattchu wrote:
28 Feb 2024, 21:07
Ok, thank you for the reply and explanation.
Venturiation
Venturiation
101
Re: Mercedes W15
Mounted floor
Owen.C93
Owen.C93
177
Re: Mercedes W15
Flattened the floor edge towards the rear as well.
Surprising amount of change.
mantikos
mantikos
Re: Mercedes W15
Owen.C93 wrote:
28 Feb 2024, 22:39
Stand corrected
El_KaPpa
El_KaPpa
Re: Mercedes W15
Of course I struggle. I just don’t quit.
Goblin42
57
Re: Mercedes W15
Spent the past 15min trying to understand what changes are you guys talking about, it's literally the same spec as testing , the only change is how visible the sensor lines in the floor
wjpbill
wjpbill
Re: Mercedes W15
The sidepod front underside now appears the same shape as it was in the launch render, sort of scalloped underneath.
At testing it wasn’t like that from the images and coverage I watched.
Re: Mercedes W15
The angle of the rear push-rod is extremely shallow. Can't be good for the dynamics of it, but I guess there is an aero benefit.
Gabriox
Gabriox
Re: Mercedes W15
wjpbill wrote:
28 Feb 2024, 23:56
It might be the angle that's making it seem like it has underbite like the renders. That Picture was taken headon so it might be deceiving. Apart from that i can't see any other differences from testing and now
SparkyAMG
Re: Mercedes W15
I don't think the floor's rear corner has changed, it looks like angle / lighting differences.
Hard to tell if the side pod inlets have changed from the front. I wouldn't be surprised if the underbite version showed up in the short term but I wouldn't have expected any big changes for this weekend.
Stu
Re: Mercedes W15
PlatinumZealot wrote:
29 Feb 2024, 03:46
Welcome back PZ.
This matches my analysis, I’ve always been under the impression that the more horizontal the link the higher the loads are at the pivot, due to the effect of motion ratio; this also has a big impact on the sensitivity to changes in spring rate & damping.
It would be very interesting to see the innards of this set-up to see if there are any neat solutions regarding the motion ratio.
Stu
Re: Mercedes W15
El_KaPpa wrote:
28 Feb 2024, 22:04
The use of blue tape here is interesting! It looks as though the car is ‘out’ in the photo (there is another pic further up that shows the tape on both sides as well, but that is in the garage, so could be for transportation only, or being used as a ‘blind’)
