autogyro wrote:This is why I suggest ways to directly use the brake energy rather than trying to store it all x.
The Lithium is not used up even when batteries are depleted.
Re-cycling is the answer here, then it will never run out.
When you burn fossil fuels they are gone and you increase CO2 and pollution.
There realy is no comparison. Electric is the future.
Not 100% sure, this is as easy and straight forward as you make it sound Autogyro.
AutoUni wrote:
Das Recycling von Traktionsbatterien stellt derzeit eine Herausforderung dar: Es existieren heute noch keine wirtschaftlich und ökologisch tragfähigen Lösungen im industriellen Maßstab zur Rückgewinnung von Lithium und anderen Aktivmaterialien, die eine Zurückführung als Sekundärrohstoff in die Batterieherstellung ermöglichten.
In a roundabout way it says:
The recycling of traction batteries presents currently one of the greatest challenges.
At the moment, there are no economical and ecological sensible solutions for the industrial recycling of Lithium and other active materials and their return into the production process of batteries.
As far as I know, you don´t recylce the Lithium, you mainly gain Cobalt,Cooper and Nickel from the recylcling of Lithium-Ionen batteries.
But feel free to come to Wolfsburg on 15.02.2011 to present your solution, I´m sure people will listen with great interest to any sensible and meaningful sugesstions.
some infos on the subject:
http://www.meridian-int-res.com/Projects/EVRsrch.htm
https://www.autouni.de/autouni_publish/ ... 011-1.html
This is not an argument against electric or EV´s, it´s just to make sure people see both sides of the coin.
EV is a solution but it is not the only solution.
Everything has it´s up
and it´s downsides, we should not forget to keep both in mind, and try to find a sensible solution forward for the future.
EV´s and electric propulsion is no exception here.
If done the wrong way, we just replace one monopol with another one, and one way to kill the planet/nature with another.
Don´t pretend you have all the answers, because you haven´t even ask all the questions yet.
Anyway Merry Christmas autogyro
