Even if using non-moving mechanical parts, there are ways & means, inc' perhaps by
managing flow energies, & coiling the linear pipe-work into a space-convenient helical shape.
See below a drawing of a patent expired double-cone system:
What is he using as piston rings?Brake Horse Power wrote: ↑26 Feb 2021, 00:16Nicely made engine block you got there!
Another project i came across (again) is this guy working on a 50cc engine with oval exhaust port at 100% of cylinder bore width. Radical transfers, head, exhaust channel. Well basically everything
Was
https://youtu.be/c92CQuHdP1Q
Trapped L-shaped ring in screw-together piston, & it proved ah, problematic...Pinger wrote: ↑01 May 2021, 21:58What is he using as piston rings?Brake Horse Power wrote: ↑26 Feb 2021, 00:16Nicely made engine block you got there!
Was
Actually gg, Yamaha did in fact develop their 4T EXUP regulatory system via their YPVS 2T
He'll very likely find the same problem with the exhaust bridge that everyone else has.Brake Horse Power wrote: ↑04 May 2021, 23:27No one said it was easy. I like his over ambitious ideas. The piston is cool as well. Curious to see how it will run with the bridge installed. Would be good to get that running first with the whole new intake
He'll probably make the big power he expects but acceptance of an engine spewing fresh mixture out the exhaust port will not happen.
