I think if there is only merc pu at the grid and if merc pu starts to fail back to back Ham's pu would wait until finish line.
Bottas had puncture again but ham had nothing again.
Max:“Good thing that Alex takes the podium and score some good points”
Welp no mr nice pr guy anymore it seems at least with ziggo“Well yeah, that’s your conclusion but if you trail your teammate with 30-40 seconds you can hardly say he did a good job. Still nice for Alex to score a podium though”
Not 5. Maybe it is, but if it is within your powers you stay at 2. Also helps with an over or undercut. Max was faster then Perez whilst Albon could not keep up with him. Barely, but not.godlameroso wrote: ↑30 Nov 2020, 00:42In Albon's defense, he stayed within 5 seconds of Perez just like Verstappen stayed within 5 seconds of Hamilton for much of the race. 5 seconds is the distance that your aero starts being affected by the car in front. Why couldn't Albon or Verstappen close in on the car ahead? Answer: they lost downforce when they got close and don't currently have an engine that can make up for the aero that's lost following(Next year, oh if only Honda were allowed to do an in season update this picture would be drastically different). I'm sure they'd be able to pull away from, or keep at bay if the roles were reversed however.
Interesting that he didn't need a new one after the shunt, looking at the state of the rear and the G force meter, I was sure he'd be taking a new one.godlameroso wrote: ↑28 Nov 2020, 03:22So what's the result of his shunt? I'm guessing he's starting from the pitlane as I'm sure he's getting a new power unit and transmission to go with the spare chassis. That was an expensive mistake to say the least.
The crash was in FP2, therefore with an older engine and gearbox... The ones used in the race are not installed until after FP2 (for FP3, Qualy and the race)... The engine may have been lost but it wouldn’t matter in terms of penalties, they just have one less engine in the pool (the only problem would be if their current race engine is the last one available, which means that they will have to use it for Practice and therefore increase the mileage.GhostF1 wrote:Interesting that he didn't need a new one after the shunt, looking at the state of the rear and the G force meter, I was sure he'd be taking a new one.godlameroso wrote: ↑28 Nov 2020, 03:22So what's the result of his shunt? I'm guessing he's starting from the pitlane as I'm sure he's getting a new power unit and transmission to go with the spare chassis. That was an expensive mistake to say the least.
I'm now guessing, but based on what Honda has done in the past, they probably would of sent that entire unit off for full inspection at Sakura after a hit like that and used a different PU from their pool. Bodes well for reliability regardless, their physical components are looking robust.
Just out of curiosity, what simulator?godlameroso wrote: ↑30 Nov 2020, 17:36The outer loop race this weekend will be interesting. Having sampled the track on the simulator . . .
Of course..SmallSoldier wrote: ↑30 Nov 2020, 06:04The crash was in FP2, therefore with an older engine and gearbox... The ones used in the race are not installed until after FP2 (for FP3, Qualy and the race)... The engine may have been lost but it wouldn’t matter in terms of penalties, they just have one less engine in the pool (the only problem would be if their current race engine is the last one available, which means that they will have to use it for Practice and therefore increase the mileage.GhostF1 wrote:Interesting that he didn't need a new one after the shunt, looking at the state of the rear and the G force meter, I was sure he'd be taking a new one.godlameroso wrote: ↑28 Nov 2020, 03:22So what's the result of his shunt? I'm guessing he's starting from the pitlane as I'm sure he's getting a new power unit and transmtHission to go with the spare chassis. That was an expensive mistake to say the least.
The one in the man cavezibby43 wrote: ↑01 Dec 2020, 02:35Just out of curiosity, what simulator?godlameroso wrote: ↑30 Nov 2020, 17:36The outer loop race this weekend will be interesting. Having sampled the track on the simulator . . .
Very nice. I didn't know if you were referring to a personal setup or alluding to comments made by one of the RBR drivers.godlameroso wrote: ↑01 Dec 2020, 03:37The one in the man cavezibby43 wrote: ↑01 Dec 2020, 02:35Just out of curiosity, what simulator?godlameroso wrote: ↑30 Nov 2020, 17:36The outer loop race this weekend will be interesting. Having sampled the track on the simulator . . .![]()
