I'm not "that" surprised by ferrari being good on this track, as they were good in baku and monaco. However here they look better still, and even sainz is up there. He wasn't earlier in the season.
LEC had an Alfa Romeo starting a push lap just in front of him in the final corner, he lifts perhaps some aero wash forcing him to. He can still clean up the final sector, perhaps easier on the tyre in S2. He has a big margin there.dialtone wrote: ↑15 Sep 2023, 18:22LEC v VER
https://i.imgur.com/prm7f5a.jpeg
SAI v VER
https://i.imgur.com/QgbL9tQ.jpeg
LEC (green) v SAI (red)
https://i.imgur.com/WoDhybY.jpeg
* Ferrari has better top speed, particularly with DRS on.
* T1 is alone a pretty big chunk of the difference with LEC, hard to know if Max was simply going easy into T1 but LEC has certainly a different interpretation from SAI.
* Ferrari is very good in the 90deg corners, LEC in particular
* Only fast corner with high DF is last corner and LEC made a pretty big mistake there that SAI didn't and instead matched Max.
* SAI has more top speed advantage than LEC in particularly after T13 where LEC must have made another error.
I think LEC had a great first half of the lap but tires overheated out after T13 as every corner past that shows more signs of bad traction out of corners.
SAI was running an even lap overall and allowed the tires to last through it
VER seems to be chilling a bit more but does have some top speed lacking particularly in the top end of the curve so more aero drag, interesting they aren't pushing the car more in the corners, they shouldn't be even with Ferrari in the corners if they are running more DF.
not that it makes much of a difference, but the car ahead of him was Gasly. Probably caused minor turbulances, yeah.scuderiabrandon wrote: ↑15 Sep 2023, 19:31LEC had an Alfa Romeo starting a push lap just in front of him in the final corner, he lifts perhaps some aero wash forcing him to.
Actually it was a Haas. Doesn't really matter I think defintitely a bit of aero wash in the final corner for sure. Regardless the fnal sector needs work.search wrote: ↑15 Sep 2023, 20:08not that it makes much of a difference, but the car ahead of him was Gasly. Probably caused minor turbulances, yeah.scuderiabrandon wrote: ↑15 Sep 2023, 19:31LEC had an Alfa Romeo starting a push lap just in front of him in the final corner, he lifts perhaps some aero wash forcing him to.
doesn't matter indeed, but it was Gaslyscuderiabrandon wrote: ↑15 Sep 2023, 20:24Actually it was a Haas. Doesn't really matter I think defintitely a bit of aero wash in the final corner for sure. Regardless the fnal sector needs work.
My badsearch wrote: ↑15 Sep 2023, 20:31doesn't matter indeed, but it was Gaslyscuderiabrandon wrote: ↑15 Sep 2023, 20:24Actually it was a Haas. Doesn't really matter I think defintitely a bit of aero wash in the final corner for sure. Regardless the fnal sector needs work.
https://i.imgur.com/C8PWvkr.png
The race is won on Saturday (as long as you don't bottle the strat on Sunday).KimiRai wrote: ↑16 Sep 2023, 02:09Mark Hughes says "On the one hand Ferrari historically runs a little lighter than Red Bull on Fridays, but GPS suggests the red cars were running their power units conservatively – leading to the inevitable conclusion that Ferrari is genuinely fast, and that Red Bull – on Friday at least – was genuinely struggling over a single lap", but also adds "its one-two form in the headline times was not repeated in the long runs where its tyre degradation rate was higher than that of Red Bull, Aston Martin and Mercedes."
