In order to fit a larger turbo and MGU-H Honda first had to make more space by redesigning the plenum and variable length inlets and change the layout of the cylinder head ancillaries, and there wasn't enough tokens to do all that in 2015.jure wrote:I generally agree, but you should know that Renault has problems with a very small portion of the engine - ice (combustion chamber, injectors,...),.. their ers and general architecture of the engine seem to be ok. And they also used last year's tokens to install larger turbo,.. Honda seems to require large engine architecture redesign and thus large amount of tokens.ME4ME wrote:This might not be a populair view, but I would like to express it anyway:
Mclaren-Honda should stop making excuses.
Renault was very effective with the use of their tokens last winter, it can be done.
To me this 40 token requirement in order to become competitive sounds like another excuse. For so long, they have argued that there was nothing wrong with their PU architecture, Size Zero, the turbo size, or since 2016 their ERS systems. Now they need 40 tokens.
That said, it seems Honda wasted last year's tokens for far too small gains. They used them for combustion chamber modification (and some other things??? - can't remember), but they still seem to be a long way behind in this department. I wonder, wouldn't it be wiser to spend last year's tokens right at the end of the year and combine them with this year's tokens. This way, they would have more tokens left for modifications through this year. Last year was a flop anyway.
Instead Honda appears to have used the tokens they had left late last year to improve the bottom end of their engine, which won't do much for power output but should improve reliability.
It seems Honda have underestimated both MGU-H power requirement (60-70 kW vs 90 kW of last years Mercedes) and the air requirement of the engine, which have caused them to fit a turbo/MGU-H that is too small. Once they have discovered this, fitting a larger system isn't a simple modification due to the packaging.
