hardingfv32 wrote:I'm not sure that expecting the driver to hold the throttle down a little is going to work.
Presently when the driver gets off the throttle that part of the engine's map associated with off throttle blowing begins. When the driver gets back on the throttle he has a normal throttle map. It is a well locate on and off position.
Now you are proposing that he find a throttle position just off 0% throttle. How does he do this rapidly at say his braking point? This is a very fast foot movement and at this point, not requiring an accurate lift stopping point.
Here is what I meant by "long" throttle pedal:
To all intents and purposes the engine response to throttle position remains identical, but there is an extra coupla inches of mechanical dead zone added. Basically he would really need to pull his leg way back to get "fully off" the throttle, it gives a big band that is not "fully off", but barely on, and that lets the engine map continue to ferociously hot or cold blow the diffuser.
Again all of this based on the notion that throttle response doesn't have to be linear (can't see the rule that says it must), and that the FIA exhaust/diffuser regulation only kicks in at "fully off the throttle", i.e. idling at 0% (haven't actually seen the technical note, just going on what James Allison said)
