Makes perfect sense then if it was the RB6!
Thanks
sAx
I thought they normally took a day at a time each? looks like jensons gonna have todo the donkey work.raymondu999 wrote:Button will take days 1 and 2 for McLaren; Hamilton days 3 and 4 of the February 7-10 test.
i agree, double diffusers were banned at the end of 2010, but in 2009 the double diffuser made the difference. teams with kers failed that year. in 2010, the exhausts were close to the diffuser, in 2011 they were futher. do you understand my point of you?raymondu999 wrote:yace - double diffusers were banned at the end of 2010; not 2009. Also; how are you differentiating between blown floor; and blown diffuser?
There was a second test at Barcelona to make up for the lack of Bahrain so there was just as much testing as scheduled, and on a better testing track.richard_leeds wrote:The test in Bahrain was cancelled last year, so MacLaren only had two test sessions, that makes their comeback in Australia with a completely untested diffuser so impressive.
If that is the case then its not an advantage that would last as rear wings are pretty easy to copy, id also be surprised if it were the case, the rules are quite strict and the wings looked pretty optimized last year.csponton wrote:source http://spontoncristiano.blogspot.com/
The McLaren MP4-27 which will be presented Feb. 1 in Woking will have a rear wing revolutionary. Nothing could be seen even now in the circus. This wing was designed to work with the best possible discharges in high position and make yoo can effectively use the DRS.
Unless it relies on something less easily changed in the aero of the rest of the car.ell66 wrote:If that is the case then its not an advantage that would last as rear wings are pretty easy to copy, id also be surprised if it were the case, the rules are quite strict and the wings looked pretty optimized last year.csponton wrote:source http://spontoncristiano.blogspot.com/
