McLaren MP4-29 Mercedes
gandharva
gandharva
252
Re: McLaren MP4-29 Mercedes
Gusgus
Gusgus
acosmichippo wrote:but is suspension considered "bodywork"?
avatar wrote:But aren't there specific exemptions (wheel/tyre,brake ducts,the nut behind the wheel, suspension/steering elements, driveshafts)
Indeed, suspension parts are not considered as bodywork by the rules ("All entirely sprung parts of the car in contact with the external air stream"). But article 3.15 says the following :
Article 3.15 of the 2014 F1 Technical Regulations wrote:With the exception of the driver adjustable bodywork described in Article 3.18 (in addition to
minimal parts solely associated with its actuation) and the ducts described in Article 11.4, any
specific part of the car influencing its aerodynamic performance
- Must comply with the rules relating to bodywork.
- Must be rigidly secured to the entirely sprung part of the car (rigidly secured means not
having any degree of freedom).
- Must remain immobile in relation to the sprung part of the car.
The FIA could state that those wishbones "influence the aerodynamic performance of the car". I don't know if they will, but they surely can.
adrianjordan
bryanbrink wrote:If so, would the rest of the aero work with the other nose types? For one thing the dog ear camera positions are not there and that seems pretty core to the design on the Merc and Ferrari?
Wouldn't they be attached the actual changeable (as opposed to the main chassis) nose section anyway, so could easily be designed differently if what you suggest is right...
Favourite team: McLaren
Shakeman
Can someone explain how these venetian blinds are beneficial?
These layman's eyes see drag but where is the benefit coming from that extra drag? More air directed over the top of the diffuser?
Interested to know...
adrianjordan
IMHO they shouldn't, because it's not something that the other teams can't copy easily (even if the positioning of suspension means it's not as effective for them) and is an interesting design...
...so they probably will.
danielk
danielk
Shakeman wrote:Can someone explain how these venetian blinds are beneficial?
Well im assuming at high speed they open up and therefore are creating minimal drag, then when cornering they close and create downforce where drag is not an issue.
but i could be very wrong
motobaleno
indeed "influencing its aerodynamic performance" is much more specific than "aereoneutral" . "aeroneutral" could be interpreted as related only to the pure profile/shape/design (i.e. wing). but if one is honest is impossible to deny that such a thing does not influence the aerodynamic performance of the car
motobaleno
danielk wrote: Well im assuming at high speed they open up and therefore are creating minimal drag, then when cornering they close and create downforce where drag is not an issue.
the movement of the suspension arm is minimal. probably they will "open" or change their configuration enough to produce some beneficial effect...but the drag will remain almost all there
daveyrace wrote:They look almost like paddles, the lower one is definitely a different shape to the upper.
http://i.imgur.com/lHkSePi.jpg
So they made two superposed 'Blonchimont bells'' out of the upper wishbones ?
the EDGE
the EDGE
68
Are the black u-shaped things on top of the side pods at the front edge sensors or vortex genorators?
I don't recall ever seeing anything like them before
adrianjordan
the EDGE wrote:Are the black u-shaped things on top of the side pods at the front edge sensors or vortex genorators?
We think they're cooling chimneys....apparently Sauber have had them before...will try and find a picture...
f1rules
f1rules
621
looking at this Picture maybe they are meassuring devices
http://www.formula1.com/wi/enlarge/0x0/ ... 9ja038.jpg
motobaleno
guys, the more I look to these venetians the less I understand how the hell they can open up...
danielk
danielk
f1rules wrote:looking at this Picture maybe they are meassuring devices
I that picture they appear far too boxxy to be beneficial. And no longer look like they did in other images. Indeed they do look more like measuring devices from that angle
adrianjordan
Here we go, all the way back in 2011 on the C30...
