Alpine A521
Re: Alpine A521
In my opinion, no not at Bahrain. It's not one of these tracks where you have long sweeping turns that you accelerating out of from a fairly low speed. Bahrain is more slam on the brake, release the brake and turn while getting back on the gas, straighten the car while getting the car up to enough DF speed and floor it.
There was an analysis on the autosport site that showed that Alpine was generating more Gs in launch than most(top 3 drivers). While McLaren seem to be engauging their deployment at higher speeds and kept it on later into the staight. So maybe their deployment plan was part of the issue.
SiLo
139
Re: Alpine A521
What I don't understand is that the bulk they added to engine cover doesn't really seem to have been removed from the sidepods? Maybe I just haven't seen good enough pictures yet to show some comparisons.
Felipe Baby!
PowerandtheGlory
PowerandtheGlory
Re: Alpine A521
SiLo wrote:
15 Apr 2021, 11:39
Agreed. Im not an aero junkie, but the car's profile is shallower at the rear, and combined with the new floor which might pull air around to energise the diffuser it might be the idea. But lets consider that the bodywork they currently have is conservative and there might be tighter packaging to arrive. 1st race of the season i think the team played it safe, and found a few issues, they've had a lot of time to implement fixes and we'll see what the package looks like in Imola..
Edit: i suspect the 'width is mainly due to the split in the air intake, which is simply carbon tubing.. so no real weight penalty.. just a wider airbox..
“I don't believe in luck, luck is preparation and taking your opportunity” Ross Brawn
Re: Alpine A521
I wonder if the roll hoop was homogenized, therefore, this was the only option to make a change.
I can see where in the 2020 version of this has little space behind the lower hoop air intake rad and the upper hoop tube. I can see that could cause air flow problems on the lower hoop intake. The lower hoop exhaust would also heat the upper hoop tube. The 2021 solution gives us better flow on the lower air intake and a cooler upper intake without changing any of the 2 entries. Maybe, that is all they were trying to do?
_cerber1
266
Re: Alpine A521
new side flap of the front wing
aerofoilf1
aerofoilf1
247
Re: Alpine A521
New front wing first comparison
aerofoilf1
aerofoilf1
247
Re: Alpine A521
New S-Duct inlet position
JordanMugen
86
Re: Alpine A521
aerofoilf1 wrote:
15 Apr 2021, 13:34
https://pbs.twimg.com/media/EzAwYj6XMAA ... ame=medium
Good! Why didn't they do this earlier? It seems intuitive that the Y250 vortex will be better controlled if the wing tips are closer together...
I.e., generate them together, instead of generating them separately and hoping they will link up by themselves downstream (with the sensitivities that entails).
Re: Alpine A521
How the ducts look from behind :mrgreen:
Re: Alpine A521
diffuser wrote:
15 Apr 2021, 12:50
Gonna reply to myself and add some of Blackout's picture to explain what I'm attempting to say ...
edit
And here was this article last year https://www.gpblog.com/en/news/61101/br ... tely-.html
"There is already a team that has reported a cooling problem with their car to us. They can't drive it like that for the next two years.
I beleive that was Renault.... both cars overheated in 2020 Hungry?
So they would have needed tokens to change the Roll hoop air intake. They then decided to make the suspension change with the tokens and went with the new air intake change that didn't need tokens?
That's my Guess anyways.
2020
2021
We can clearily see the "/ \" existed in 2020, it was just further down.
And to borrow Scarb's drawing
aerofoilf1
aerofoilf1
247
Re: Alpine A521
FW17
171
Re: Alpine A521
diffuser wrote:
15 Apr 2021, 17:38
diffuser wrote:
15 Apr 2021, 12:50
2020
https://i.ibb.co/m9VBXqN/TT4wy-R0-2.jpg
2021
https://i.ibb.co/yRhhSXz/Jbfj-Zxm-3.jpg
https://i.ibb.co/xgKqVcw/Ex-WHW7z-WUAIrp-XG-2.jpg
Wouldn't have been simpler to run the top duct to the radiators and lower duct to the turbocharger? Rather than all the crisscrossing of ducts?
Re: Alpine A521
FW17 wrote:
15 Apr 2021, 18:20
diffuser wrote:
15 Apr 2021, 17:38
diffuser wrote:
15 Apr 2021, 12:50
2020
2021
I added and edit ...
Re: Alpine A521
diffuser wrote:
15 Apr 2021, 18:23
FW17 wrote:
15 Apr 2021, 18:20
diffuser wrote:
15 Apr 2021, 17:38
2020
2021
Add replying to myself to add this ...
https://www.autosport.com/f1/news/renau ... 8/4981208/
Re: Alpine A521
