Mercedes W14
Henk_v
Henk_v
88
Re: Mercedes W14
17 Feb 2023, 18:24
https://i.imgur.com/GTl49UQ.jpeg
This image shows how rounded the nose is, similar to the Williams honestly
Means they prioritized outwash over downforce..
Re: Mercedes W14
Goblin42 wrote:
17 Feb 2023, 19:31
W13 is pretty much the same in that respect
W13 for comparison. also has the inner two floor fences converging & close together as well as above the floor leading edge
240
Re: Mercedes W14
May have to do with the radiator inlet flow.
Re: Mercedes W14
Rear view from the roll hoop. Some extra hidden louvres
Venturiation
Venturiation
102
Re: Mercedes W14
17 Feb 2023, 20:21
https://i.imgur.com/Ra6WM5B.jpeg
Rear view from the roll hoop. There are some louvres in there right?
What are those 2 holes in the bathtub
Re: Mercedes W14
Venturiation wrote:
17 Feb 2023, 20:22
17 Feb 2023, 20:21
Louvres? It's within the legality box for cooling apertures I believe
Venturiation
Venturiation
102
Re: Mercedes W14
17 Feb 2023, 20:25
Venturiation wrote:
17 Feb 2023, 20:22
17 Feb 2023, 20:21
Yes the louvres, is it an illusion or the two « slides » are closed at the end
JPower
JPower
43
Re: Mercedes W14
The high mounted cooling and low sidepods give it an odd looking shape for an F1 car. Interesting how it and the Aston have the cooling louvers placed on the very top of the car.
Spoutnik
Spoutnik
Re: Mercedes W14
She's beautiful
Goblin42
57
Re: Mercedes W14
Spoutnik wrote:
17 Feb 2023, 21:06
She's beautiful
Small fin behind the driver's head to help with managing cockpit losses
Venturiation
Venturiation
102
Re: Mercedes W14
more details here by Fulvio vigilante
De Jokke
Re: Mercedes W14
W14 analysis by a former merc f1 aerodynamisist:
Mercedes AMG + Hamilton => dreamteam!
If you can't beat'em, call Masi!
Re: Mercedes W14
W13 had the sidepod radiators placed quite forward, leaving them a very small amount of room for a complete sidepod redesign - on top of bouncing and correlation issues. Bottom SIS was also sticking out a lot.
W14 has its radiators placed quite more to the rear and seems to leave a lot of room to implement either RB or Ferrari or a completely different style of sidepods without the need for massive change to internals. Bottom SIS looks to be in the floor now.
I don't expect any issues with bouncing like last year, so maybe after they have their true pace reference a few races in, they might want to have the room to change their approach and have placed those radiators accordingly.
As things stand right now, even Ferrari could make a switch to RB sides and vice versa, Williams seems to have placed the radiators in the most extreme position...
wogx
Re: Mercedes W14
It's still not an ideal overlap, but...
I saw a tweet that the cockpit was moved by 20 cm. From these photos - I don't believe it IF the wheelbase is the same (some users stated so)
Re: Mercedes W14
Cockpit moved rearward a bit. Perspective distortion is heavy on tyres, but that much is clear. Front wing endplates are still aligned completely so cockpit was definitely moved back.
