autogyro wrote:
Sorry Machin, I just noticed that you are not fully aware of how my geartrain design works. I did not wish to bring it up and risk another ban, so I will be brief.
I think what got people annoyed before was that you tried to turn every thread into a sales pitch for your gearbox concept... but you would never really go into any detail... just said "mine is better"... you seem more willing to discuss technical details now and that's what we're here for (well, most of us... there seems to be lots of driver related threads these days!)
I might be wrong about your gearbox... so I'll try and say how I think you intend for it to work as best I can by considering a simple 2 gear ratio (single epicyclic) version:-
In top gear the whole thing is locked together as one big mass, so one turn of the input equals one turn of the output, 1:1, and the outer ring gear part (red) forms the core of an electric motor, and so can be driven around adding torque (i.e. the KERS input). We can also see here why it looks to have more inertia than a normal gearbox -there is a lot of material which is far from the axis of rotation, whereas the gears in a normal gearbox rotate about their own centres.
In the bottom gear arrangement the ring gear (red) is held stationary. The planet carrier (grey) turns with the input causing the planets (green) to proceed around the sun gear (blue) causing it to rotate at some lower speed depending on the respective sizes of the gears (say 2:1). Because the ring gear is held stationary we can't use the motor to add torque to the output....
To solve this we could add another KERS motor to the transission... (addig additional weight)...
...or we could add another epicyclic to the arrangement, giving 4 gears (both ring gears locked, ring gear 1 locked, ring gear 2 locked or neither of them locked)...
In the both ring-gears locked scenario ("gear 1") we still can't use either of the motors (since both ring gears are locked).
In "gear 2" we can only use the second ring gear's motor (since the first is locked), so it must be sized for the full KERS output.
In "gear 3" we can only use the first ring gear's motor (since the second is locked), so it
also must be sized for the full KERS output.
In "top gear" we can use both motors, but now we have potentially "too much" capability (i.e. more power than the rules allow, or more power than the rest of the KERS system can cope with since each motor is sized for 100% of the allowed output)....
So to my mind it appears that by linking the motors to the epicyclic ring gears it means we can't use all of them all the time, so we're carrying around dead weight..
Or maybe I've missed something/got something wrong?
