McLaren's bulging flap is back. It looks like it's inflatable actually
yes. hope they are under the maximum height:Holm86 wrote:The flap that goes over the sidepod intake isnt it positioned higher than earlier??
smaller air outlet?Forza wrote:Japan F
It looks like they have reprofiled the airbox fairing to alter how the sidepod air exhausts out at the back.Forza wrote:Japan FP1
Has been on the car since last year. That little concave part on the main element allows them to run a narrower more vertical DRS flap. IT helps the DRS.McMrocks wrote:smaller air outlet?Forza wrote:Japan F
and in the lower pic: look at the main element. i don't understand the shape in the area next to the endplate. What advantage should this bring?
Interesting development. They not only changed the width inbetween the panel and the upper edge of sidepod, they also changed the shape of it. The vane extends now more inwards. This was the Singapore one:Forza wrote:Japan FP1
I believe the previous version only created a more laminar flow on the sidepod roof to help the coanda effect on the exhaust. But i think the new one create downforce in itself beside creating a more laminar flow.turbof1 wrote:Interesting development. They not only changed the width inbetween the panel and the upper edge of sidepod, they also changed the shape of it. The vane extends now more inwards. This was the Singapore one:Forza wrote:Japan FP1
Here we have the new turning vane in side view:
The new one is most certainly legal; it isn't higher then the highest point of the sidepod. Also it looks the little winglets right in front of the turning vane, work now more in conjunction with the vane.
The fact that the vane isn't higher then the top edge of the sidepod, while the previous one already came very close to that, makes me suspect they changed the sidepod entrance layout. I can't find a good image from FP where that shows up. Does someone perhaps came accros a frontal image from the McLaren from this FP?
