And the wheels appear to be revolving.wesley123 wrote:the rear wing seems to be pivoting forward?
The end plate is exactly paralell to the floor. The line on the road creates an optical illusion.
Hit it with a hammer and see what the effect is.jtc127 wrote: I've made carbon parts out of 3 layers of twill and plain weave, none of them wrinkle/twist like that.
I see the forum Sherlocks are already turning their attention to the rear after resolving the front.wesley123 wrote:the rear wing seems to be pivoting forward?
Sauber ran a similair, which is less introduing like the Lotus one.Timstr wrote:This looks active. The plumbing needed for a passive device is lacking.
Sauber's device is not unlike Lotus and Merc's which are passive systems.Huntresa wrote:Sauber ran a similair, which is less introduing like the Lotus one.Timstr wrote:This looks active. The plumbing needed for a passive device is lacking.
It is extremely thin so is probably just a panel to allow flo-viz to show what is happening in this under wing area.Timstr wrote:So what's with this vertical channel? under the rear wing? DRD?
