richard_leeds wrote:The bodywork isn't actually failing, so I imagine what is essentially a cosmetic fix (more insulation) has a low priority. The other factor might be a lack of space for more insulation. So they'll need new side pods with slightly more clearance between the bodywork and exhaust. That's not a quick fix.
So I expect we'll not see any change until the next test.
Actually, seeing from top it seems odd that the exaust pipes are so close to that part of the bodywork. If so, then it has a tight bend outwards (to the 10cm straigth pipe) after a curve inwards. Probably a really tight packaging. Anyway, it seems a bit odd. They should have known better. They have the same side effect YOY. Why be careless about it?
"Devil is in the details" or "When it came to details s#it happens"!!
On a discipline where is all about details and fine details....Seems a bit odd. They are the only team where it happens again and again.
Probably wouldn't matter if they have accomplished in the past but as their cars have revealed themselves as flops, we pay a bit of extra attention for those recursive little faults.
