raymondu999 wrote:2013-spec Vettel IS infallible on formation laps, yes.
Well your view has changed somewhat.
So your opinion is "2013-spec" Vettel did not lock up whilst trying to heat the brakes and tyres, so it must be the brakes at fault, correct? Therefore maintaining his infallibility throughout 2013(your opinion as expressed previously).
Did Vettel have any further brake issues throughout the race?
Monza has the heaviest braking zone in F1, as it has the highest speed going into one of the slowest corners. Overall it is 2nd behind Montreal in terms of demand on brakes. Yet apart from the very first corner of the race, where Vettel locked up again(Do you reason it was brakes failing him, again?), Vettel appeared to have no further issues during the race.
After the race was not even the slightest mention of the brakes being an issue. Not a peep.
As I have stated before, I believe it is either brake balance, or too much brake pressure being applied. Either way it is down to the driver to sort out, and therefore driver related error.
We can see that it happened on the warm up lap, and into turn 1 of the race. After that nothing.
Brake problems do not mysteriously go away.
