Scuderia Ferrari SF70H
ScrewCaptain27
577
jagunx51 wrote:
White part is a foam block used to measure tyre expansion.
http://i1376.photobucket.com/albums/ah3 ... mh9rzh.jpg
- Serj Tankian
Re: Scuderia Ferrari SF70H
probenprinz
probenprinz
I have a question to aero guys :
but when you mount this kind of machinery (in this case overlapping the rear wing plates) you don't have changed the flow you are trying to measure ?
3jawchuck
3jawchuck
37
Not an aero guy, but, I'll have a shot. Looks like they're measuring diffuser and rear wheel flows and so on, so while the wing flow will probably be messy, it shouldn't make much of a difference to the measured areas.
matt21
86
AMUS is suspecting some kind of trickery in the floor due to different texture of the carbon fibre.
I would agree that there is something due to the temperature stickers.
Edit: Could they run some sort of surface cooling? Maybe this helps reducing radiator size. Or even could influence the air flow.
F1Krof
95
matt21 wrote:AMUS is suspecting some kind of trickery in the floor due to different texture of the carbon fibre.
https://imgr3.auto-motor-und-sport.de/K ... 022292.jpg
Flexi floor? Are they even supposed to flex? Are they even allowed? Man this car is a beast. #-o
Wroom wroom
.poz
.poz
51
No, the pitot tubes are on the front part of the grid so they measure the air pressure before it is altered by the grid
.poz
.poz
51
IMHO they just moved the gearbox/transmission oil radiator from the back of the car into the sidepods with linking pipes into the floor
seezung
seezung
56
Wonderfull picture from above;
matt21
86
Could be correct indeed. =D>
F1Krof
95
https://www.motorsport.com/f1/news/tech ... te-880339/
Seems like it used for cooling, like the circuit boards. Still its nature remain mysterious.
Wroom wroom
jagunx51
185
Mr.G wrote:
tpe wrote: Here is another speculation: Cables from/to batteries.
Cables to where? MGU-K/H are mounted to the ICE...
edit: adding picture
From test day #2
Different stickers locations, alignment, and blue stickers
Mat-tes
Mat-tes
30
What is the red shape cut out on the left of the side-pod panel, to the left of the infor logo. Looks like a window with red tint (like some infra red lense) of some sort, could there be a camera of some sort placed there looking at the floor?
Let's speculate there is a camera, could it then be used to monitor the possible pipe that passes just in front of it, monitoring its temperature?
It's maybe a reflection, but from here it really look like a transparent surface.
If it's not that, then do some of you have any idea what it could be?
matt21
86
Mat-tes wrote:https://imgr3.auto-motor-und-sport.de/K ... 022292.jpg
Which part do you mean exactly?
