AMG.Tzan wrote: ↑09 Apr 2017, 21:39
ENGINE TUNER wrote: ↑09 Apr 2017, 18:30
basti313 wrote: ↑09 Apr 2017, 17:40
I thought you are one of the guys knowing the rules?
What is the rule on that? how much(and which part) of the car must be in the start box?
Yeah I was also surprised with that...because if you can park outside your box then you might have an advantage in wet conditions like today...essentially if your box has a wet patch you can avoid it and have a better start!
- Not only that - grip in the dry, line to the first corner, blocking drivers behind and so on. There's a reason for starting boxes.
- It's not like it was 10 cm sideways which should be penalised anyway but I'm guessing that was the lateral leniency rules expert above was talking about
![Wink ;-)](./images/smilies/icon_e_wink.gif)
Not half of the damn car outside. BTW didn't it help to block Bottas later?
- Maldonado got five seconds for starting behind (BEHIND) his starting position, both position (some cars missing) and within his box. Guess how much he gained from that.
