Nobody even mentioned max?morefirejules08 wrote: ↑24 Jul 2022, 16:40
And no doubt had max done the same you would be lauding him as a genius
If this is what the drivers saw as well, then it might be another error by race control. It might explain how Perez got confused potentially.When the clerk of the course decides it is safe to end the VSC procedure the message
“VSC ENDING” will be sent to all Competitors via the official messaging system and, at
any time between 10 and 15 seconds later, “VSC” on the FIA light panels will change to
green and drivers may continue the session or continue racing immediately. After 30
seconds the green lights will be extinguished.
If it was a throttle issue I say go back to cable throttles, much better feel of the engine. And lighter as well. Too much drive by wire.
He went off on a very fast corner that stresses the tyres and often a place for other cars fighting. Think it was the 100% right call
Im not bitter just disapointed, so many races could of been epic battles between Max and Lec or both Ferraris vs both Red Bulls.
True, just simply pointing out how your reaction would likely have been different had it been a RB driver playing games, considering you take every opportunity to dump on Mercedes and their drivers.chrisc90 wrote: ↑24 Jul 2022, 16:42Nobody even mentioned max?morefirejules08 wrote: ↑24 Jul 2022, 16:40
it could have been a good battle indeed, but at the point Leclerc crashed, Ferrari had already missed the only chance to defend against the undercut, so not sure what was their plan on from then. It would have been difficult to get back in the lead
It wasn't, LEC made a mistake.
