I don't see how such a flexing nose could be legalbhallg2k wrote:That's not an altogether irrational idea. However, that pitstop video combined with this, from the other car...rayden wrote:This is why I don't think it is anything sinister.
The mechanics actions indicate the way the nose behaved was not expected.
i think the nose was broken on the DRS signage after the RIC incident, and it is just the outer yellow sticker holding it all together that gives it this rubbery appearance.
...makes for some pretty compelling evidence that Red Bull runs a flexible nose.
I wouldn't call it sinister, though. It passes inspection, so it's legal. For me, it just brings up questions as to why the rules are such that an obviously flexible nose is legal.
it is not surprising at all! If you read the regs you will see it written that no flexing parts are allowed, except for the DRS and up to 2cm of the FW. Why invest millions to develop a flexing part if it is very likely it will be deemed illegal? Well, unless you are Red Bull and you get away with anything.Cam wrote:I'm not surprised you can't see it. Trolls cant read. Everyone has told you it's legal, the FIA have cleared it, and unless you can provide a factual counter argument, please stop. Really.
Back to normality... Interesting to see Brawn basically admit they failed to see this red bull direction with the flexing. Goes to show there's always more than one way to get a car quick around a track. All this time red bull were working on a trick front wing, like Mercedes, yet approached it from an altogether different angle.
so, he thinks that the flexing should disappear....Ross:
Brawn hinted that Mercedes’ ‘double DRS’ meant the team was not able to explore some of the latest trends, like flexible or bendy noses and wings.
“As you say, there are some ‘structural’ considerations that we have seen this year,” he said, “but this will disappear next year — or should disappear.”
no need for insults. RB7 front wing was legal in 2011, but in 2012 it wouldn't be legal. this front wing is legal, for now.Cam wrote:I'm not surprised you can't see it. Trolls cant read. Everyone has told you it's legal, the FIA have cleared it, and unless you can provide a factual counter argument, please stop. Really.
+1elFranZ wrote:the point is these regulations are just ridiculous, not RB8's nose IMO.
when they banned renault's mass damper, that was because of aerodynamic benefits, not for mass damping itself. You know, someone could argue that a flexi nose IS an aerodynamic benefit.
not trolling nor firing, just curious of your opinion guys.
Of course he does, just like I'm sure he wants 3 years of failures to disappear too.vall wrote:it is not surprising at all! If you read the regs you will see it written that no flexing parts are allowed, except for the DRS and up to 2cm of the FW. Why invest millions to develop a flexing part if it is very likely it will be deemed illegal? Well, unless you are Red Bull and you get away with anything.Cam wrote:I'm not surprised you can't see it. Trolls cant read. Everyone has told you it's legal, the FIA have cleared it, and unless you can provide a factual counter argument, please stop. Really.
But inmediately after that rule you have the deflection test regulations. No part can be indefinetely rigid, essentially that first regulation is both impossible (everything flexes to a certain point) and useless (because the deflection tests are stating what is needed to be legal). Back in 2010 there was the same problem with Red Bull's flexing front wing. The precedent was then clearly set: if you get through the deflection test, your car is LEGAL. The FIA can change that regulation at any time during the season to counteract new developments, but as long as the cars get through the tests, at that time in position, they are that weekend legal.vall wrote: it is not surprising at all! If you read the regs you will see it written that no flexing parts are allowed, except for the DRS and up to 2cm of the FW. Why invest millions to develop a flexing part if it is very likely it will be deemed illegal? Well, unless you are Red Bull and you get away with anything.
I agree on that! If it passes the test, it is LEGAL. But, there is a precedent of FIA doing further tests not described in the regs. IIRC, back in 2007(?) FIA had to test Ferrari's floor to find out it was flexing. Such a test was not foreseen in the regs. So, I only want to say that because there is suspicion that RBR nose is illegal, FIA should test it to clear it.turbof1 wrote:But inmediately after that rule you have the deflection test regulations. No part can be indefinetely rigid, essentially that first regulation is both impossible (everything flexes to a certain point) and useless (because the deflection tests are stating what is needed to be legal). Back in 2010 there was the same problem with Red Bull's flexing front wing. The precedent was then clearly set: if you get through the deflection test, your car is LEGAL. The FIA can change that regulation at any time during the season to counteract new developments, but as long as the cars get through the tests, at that time in position, they are that weekend legal.vall wrote: it is not surprising at all! If you read the regs you will see it written that no flexing parts are allowed, except for the DRS and up to 2cm of the FW. Why invest millions to develop a flexing part if it is very likely it will be deemed illegal? Well, unless you are Red Bull and you get away with anything.
Those 2 rules together are kinda stupid, I agree you on that:
rule1 on flexing: flexing is illegal.
rule2 on flexing: flexing isn't illegal as long as you pass the tests.
It's not - Excessive flex is illegal. Flexing is just physics - everything flexes.antrock wrote:Flexing is and was always illegal with the current rules
I don't think it actually can due safety precautions; yes red bull took it to the extreme, but a nose cone has to be soft enough to absorb some of the impact force. It'll always flex a little bit, albeit normally you don't get an advantage out of it. Red Bull cleverly managed to design it that way to actually get performance out of it, and the best thing is that the FIA can't just strab rigid test on that without making the nose cone more dangerous.vall wrote:
BTW, I understand that noting could be completely rigid. It is for sure not possible for the FW, but, come on, a nose cone can be made rigid and not flexing.
There is a big difference between a flexible nose, and a flexible covering! The nose cone has to be rigid, as the wing is attached to it, and it must have been crash tested. What RBR has is a sponge type outer covering, something that is permitted under the rules.turbof1 wrote:I don't think it actually can due safety precautions; yes red bull took it to the extreme, but a nose cone has to be soft enough to absorb some of the impact force. It'll always flex a little bit, albeit normally you don't get an advantage out of it. Red Bull cleverly managed to design it that way to actually get performance out of it, and the best thing is that the FIA can't just strab rigid test on that without making the nose cone more dangerous.vall wrote:
