470
WhiteBlue wrote:Wuzak claimed it would be possible and I made an educated guess at the properties.
I did nothing of the sort.
My claim is that they do not need to have 4MJ storage, and that they would use about half that.
WhiteBlue
92
Well, you said that they would use batteries of the type they have used before, which is the A123 iron based variety. Didn't you?
470
I said they would probably use the same batteries as now. I have no idea what those batteries are.
I didn't say they would use 4MJ worth.
WhiteBlue
92
wuzak wrote:I didn't say they would use 4MJ worth.
But you said that they would drain 4 MJ from the batteries and recharge 2 MJ in one qualifying lap. And that is the biggest technical challenge that I see.
One factor is the absolute amount of charging and discharging in a given time frame. That stresses a battery. The other is the power of the charging and discharging or better the voltage that is used. In both regards the use profile that you suggest for a small battery is very much heavier than the use profile we have on the 2009-2013 KERS batteries. A third factor is the size of the battery. You suggested to go with substantially less than 4 MJ battery capacity and that something between 2 and 3 MJ capacity could be used.
Due to all those differences between the 2013 and 2014 batteries I'm sure those two batteries will be very different. I'm still of two minds about the ability of the 2013 battery to do the 2014 job. I'm just not denying any more that it can be done. Perhaps it is doable, but we have no data to confirm it.
FastCap technology from MIT. I previously posted the Signorelli Phd thesis link
I think that a fifty/fifty design from iron/phosphate (IP) battery cells and FastCap (FC) ultracapacitors would be more capable. So I suggest to look at:
12.6 kg of IP cells for 2 MJ of slow capacity
12.4 kg of FC cells for 0.6 MJ of fast capacity
FC energy density: 0.0486 MJ/kg and 0.0538 MJ/L
FC power density: 37 kW/kg and 41 kW/L
IP energy density: 0.1584 MJ/kg
IP power density: 9.3 kW/kg
The iron/phosphate battery will only be used in qualifying. During the race the FastCap ultracapacitor can handle all energy transfers. 0.6 MJ or 12.4 kg of FastCap can handle 460 kW power which is massively in excess of any energy transfer that may occur in the system. 0.6 MJ is also enough for any single braking and acceleration event. I consider a 2 MJ regeneration budget per lap The average braking energy pulse will be less than 0.4 MJ in F1. So the capacitor can handle the race transfers all on its own. To provide expanded capacity for qualifying the IP cells will back up the capacitor. They will load it up while it is being depleted by the elevated acceleration power drain in qualifying.
The backup capacity will be able to handle 117 kW power, which again is much more than required for only acceleration support.
The ultracapacitor will need 11L of volume which is no problem considering we free 65 L for not carrying 50 kg of fuel.
The most critical event will be Canada in my view. Below the Brembo PDF for Canada which gave me all figures.
http://formula1.brembo.com/schede_circu ... da_eng.pdf
Below you can see the braking time for each of the seven turns. Also shown is the peak braking power in MW, the average braking power (estimated) in MW, and the part of the electric brake power in MW. The you see the total brake enrgy budget of the turn, the rear brake budget and the electric brake budget. I'm assuming that 35% of the total brake energy goes to the rear wheels and that 60% of that is recovered by the energy recovery system for a total of 2 MJ through all turns.
Biggest recovered energy in one turn is 0.6 MJ in turn six. Biggest electric power is 280 kW in turn seven.
It follows that a capacitor of 0.6 MJ will just be able to handle the energy. It also follows that the MGU-K will be temporarily overloaded by a factor of 2.33 with 280 kW. Based of those figures I'm predicting a much more capable MGU-K than the KERS MGU for 2014. KERS MGU had to handle 0.4 MJ braking recovery with a nominal power of 60 kW. The MGU-K will have to handle five time the brake recovery with only twice the nominal power. Magically we find again a factor of 2.5 which is suspiciously close to my calculated overload factor of 2.33. Hence my believe that the MGU-K weight will not be twice the KERS MGU but probably five times.
The capacitor can handle 460 kW. A 25 kg IP battery will not be able to handle 280 kW.
It would be fun to do this for an LMP1 with 8 MJ recovery budget. I think you can easily do it with 25 kg of FastCap because you do not need to store much energy as you have to do for qualifying in F1. I bet Porsche and Audi will have a look at FastCap.
dren
227
The battery is part of the power unit, unless I read the chart wrong in the regs. Teams will not be able to change them out often.
I think teams will be lucky to absorb 1MJ a lap purely through braking. The braking energy is there to be had, but the 120kWs limits you as does the % front to back balance when braking. I don't expect teams to run an ES storage higher than 3MJ, likely less.
I'd almost guess this is why Hamilton is having braking issues in the Mercedes, they may have more rear bias, especially with the FRIC system. This could also be a component in their tire heating problems.
I don't expect teams to charge the ES at all from anything other than braking during the race, unless stuck behind a safety car.
Honda!
dren
227
And looking at those numbers for Canada, the max energy available is 1.16MJ if you are limited to 120kW. Then take your percentages of that and you get stuck with 0.24MJ a lap total recovery to the ES. That is all at 100% MGUK generating efficiency. The MGUK will probably be rated slightly higher than 120kW since the energy flow is measured at the ES and an efficiency of 95% (i think) is used per the regulations.
This leads me to assume they will drag the MGUK when braking a lot more than what you're thinking (60%). And the weight distribution will likely be a little more rear biased.
Honda!
WhiteBlue
92
dren wrote:The battery is part of the power unit, unless I read the chart wrong in the regs. Teams will not be able to change them out often.
The ES is indeed one of the six components of the power unit that fall under the sealed components rule. Teams will have only five ES storage units per season. Any exchange beyond that will cost you a grid penalty of ten places. Even more reason to restrict iron/phosphate technology - that degrades rapidly within a thousand cycles - to qualifying only.
We have 20 events in the championship with 100 laps per event. There are 25 load cyles per lap (12.5 corners). This leads me to believe that we have 50.000 load cycles for five ES packs or 10.000 per ES pack. After two or three thousand load cycles the batteries will be very tired already while the SuperCaps will be ticking over without any noticeable degradation. UltraCaps will be king under those conditions. They take millions of cycles to degrade.
dren wrote:I think teams will be lucky to absorb 1MJ a lap purely through braking. The braking energy is there to be had, but the 120kWs limits you as does the % front to back balance when braking. I don't expect teams to run an ES storage higher than 3MJ, likely less.
Objections! If a team does not fully utilize the 2 MJ another team with better technology will do it and gain a competitive advantage.
I have shown in the above post that it is possible to recover 2MJ out of 9.6 MJ available with an UltraCap system based on the FastCap spec. My calculation show a 65% front brake bias, which I think is realistic if you think about dynamic load transfer which will occur. Out of the residual 35% to the rear brakes only 60% go to the MGU-K. Nevertheless with uniform friction/electric brake bias you reach 280 kW electric brake power in Canada. The MGU-K will have to be stout to generate at that power level but that was expected. The units will be considerably heavier than the KERS MGUs.
dren wrote:And looking at those numbers for Canada, the max energy available is 1.16MJ if you are limited to 120kW. Then take your percentages of that and you get stuck with 0.24MJ a lap total recovery to the ES. That is all at 100% MGUK generating efficiency. The MGUK will probably be rated slightly higher than 120kW since the energy flow is measured at the ES and an efficiency of 95% (i think) is used per the regulations.
Your image of the electric machine design seems to be a bit narrow minded. These MGUs can be heavily overloaded depending on the thermal load status over one cycle. For very short peaks you can generate massive overloads for the machine. The inverters are more critical and have to be designed for the peak load. I think that my figures are realistic under the assumption of constant friction/electric brake bias. That assumption may be wrong. Perhaps they have location information in the enrgy management and can program variable bias for each corner individually.
648
the MGU-K is generating at about 250 kW average for about 10 sec/lap and motoring at about 120 kW much of the remaining laptime
that's equivalent to about 150 kW continuous power
the KERS task is equivalent in continuous power to only a fraction of this
so the MGU-K will be very much bigger and heavier than the KERS equivalent MGU
just to do its likely task of supplementing the ICE power at 120 kW for 70% of the laptime
it would only need to be slightly bigger capacity to implement the full permitted recovery
(you may have said this already ?)
less recovery would be a mistake
IF the full recovery rate is managable regarding demands on tyre grip
(we assume that it is ??) ........ and .........
IF the typical MGU-H recovery power is at least 100kW
dren
227
WhiteBlue wrote:Your image of the electric machine design seems to be a bit narrow minded. These MGUs can be heavily overloaded depending on the thermal load status over one cycle. For very short peaks you can generate massive overloads for the machine. The inverters are more critical and have to be designed for the peak load. I think that my figures are realistic under the assumption of constant friction/electric brake bias. That assumption may be wrong. Perhaps they have location information in the enrgy management and can program variable bias for each corner individually.
Yeah, maybe I'm a bit confused here. The energy flow diagram shows 120kW either direction. So you use a 120kW rated MGUK but overload it substantially and that's ok with the regulations?
5.2.2 Energy flows, power and ES state of charge limits are defined in the energy flow diagram shown in Appendix 3 of these regulations.
When the car is on the track a lap will be measured on each successive crossing of the timing line, however, when entering the pits the lap will end, and the next one will begin, at the start of the pit lane (as defined in the F1 Sporting Regulations).
ES state of charge cannot increase whilst car is in the pit lane or garage during the qualifying session.
Measurements will be taken at the input to and the output from the ES.
A fixed efficiency correction of 0.95 will be used to monitor the maximum MGU-K power.
Honda!
WhiteBlue
92
Tommy Cookers wrote:the MGU-K is generating at about 250 kW average for about 10 sec/lap and motoring at about 120 kW much of the remaining laptime, that's equivalent to about 150 kW continuous
it would only need to be slightly bigger capacity for the full permitted recovery
Yes, I have actually computed 9.7s according to Brembo in Canada. I havn't looked at the the remaining lap time but off the cuff I would say we are probably looking at 85 kW (40 kW from MGU-H +45 kW qualifying ES) at the remaining time except recovery. The equivalent in my view would be 115 kW. But that is a lot more than the KERS MGU is doing as an equivalent. KERS recovers 25% of the kinetic energy for 10 s which is 40 kW over ten seconds. It feeds 60 kW for 6.3 seconds and does 38.7 seconds nothing. That gives an equivalent of 14.2 kW. The MGU-K is 96% loaded. The MGU KERS is 24% loaded. Hence my opinion that Newey would dimension the thing rather for 20 kW than 60 kW.
WhiteBlue
92
dren wrote:Yeah, maybe I'm a bit confused here. The energy flow diagram shows 120kW either direction. So you use a 120kW rated MGUK but overload it substantially and that's ok with the regulations?
I think you confused the power to the engine with power to the ES. The MGU-K is unlimited in power to the ES. It is limited in energy but unlimited in power. The electric measurement IMO will only apply to power from the MGU-K to the engine. When the MGU-K is driven by the wheels it is free to generate any power. At least that could be an interpretation that I see.
dren
227
The energy diagram shows max +/-120kW. Yes, it's unlimited power to the ES, but it is coupled to the engine and that's where the 120kW is coming from or going to.
5.2.3 The MGUK must be solely and permanently mechanically linked to the powertrain before the main clutch. This mechanical link must be of fixed speed ratio to the engine crankshaft.
Honda!
WhiteBlue
92
I don't think so. The power is coming from the wheels not from the engine. I would argue the case and probably win. There is no point in a 2 or 4 MJ ES exchange between the MGU and the ES if you can not harvest the ernergy. The rule makers should know that. The box is clearly labeled "engine" and not "wheels". And in the case of recovery the power to the MGU-H is coming from the wheels. There is probably a directive about this. That or they are silly enough to waste half the energy they could be recovering. Usually when you have such an ambiguity it pays off to approach it boldly. People were getting away with bigger fish. Remember the DD and the blown diffusor, or the DDRS?
Holm86
249
This doesn't tell us much new. But its an interesting read anyways.
The 2014 season will bring with it some of the biggest changes to Formula One racing’s technical regulations for quite some time. Not only is the sport adopting new 1.6-litre turbocharged V6 engines, there are also tweaks to the rules concerning aerodynamics and a far greater emphasis on energy recovery systems. We spoke to two technical directors - Toro Rosso’s James Key and Caterham’s Mark Smith - about the new regulations and what effect they’ll have on the design of next year’s cars, but first, here is a summary of the main changes:
Engine - it’s out with 2.4-litre normally-aspirated V8 engines and in with 1.6-litre V6 turbo engines, revving to a maximum of 15,000rpm.
Gearbox - gearboxes are to have eight forward ratios - rather than the current seven - which each team must nominate ahead of the season.
Energy Recovery Systems (ERS) - in 2014, a larger proportion of each car’s power will come from ERS which, together with the engine, make up the powertrain or power unit. As well as generating energy under braking, ERS units will also generate power using waste heat from the engine’s turbocharger. Unlike the current KERS - which give drivers an extra 80bhp for six seconds per lap - the 2014 ERS will give drivers around 160bhp for 33 seconds per lap. To compensate for the extra power being generated under braking by ERS, teams will be allowed to use an electronic rear brake control system.
Fuel - to promote fuel efficiency, fuel will be limited to 100kg per race.
Minimum weight - to compensate for the increased weight of the 2014 powertrain, minimum weight has been increased from the current 642kg to 690kg.
Exhaust - unlike today where two exhaust tailpipes are used, the 2014 regulations mandate the use of a single tailpipe which must be angled upwards to prevent the exhaust flow being used for aerodynamic effect. Additionally, bodywork is not allowed to be placed behind the tailpipe.
Nose height - for safety reasons the height of noses will be reduced in 2014. The maximum height is currently 550mm, whereas next year it’s 185mm.
Front wing - front wings will be a little narrower next year with the width reduced from 1800mm to 1650mm.
Rear wing - the rear wing will also look a little different in 2014 compared to this year’s models. The lower beam wing is being outlawed and the main flap will be slightly shallower in profile.
2014 Q&A - Caterham's Mark Smith and Toro Rosso's James Key
Q: Is the philosophy of the 2014 car as radically different from the 2013 car as it sounds?
Mark Smith: Yes, I think it is. Fundamentally, the power unit is significantly different; it’s not as if we’ve gone from a 3.0-litre V8 to a 3.2-litre V8 - it’s a significantly different lump of architecture in terms of the physical size of the internal combustion engine and it also has a relatively big turbocharger assembly associated with it. The exhaust configuration - as a result of the turbo installation - is also a big departure from what we currently have. The way in which the turbo installation impacts upon the transmission is significant. We’ve had many changes of engine configurations since the previous turbo era (which ended at the end of 1988), but this is one that impacts in so many ways.
At Caterham we buy our gearboxes from Red Bull, but it impacts upon their design and that in turn impacts on installation of clutch assemblies and suspension. It’s quite far reaching.
But bigger than all of that is the cooling challenge. That’s probably the thing that, I imagine, has most people up and down the pit lane scratching their heads. It’s reasonably easy to come up with a solution that will cool, but to come up with a solution that will cool and give you the optimum aerodynamic performance is the challenge.
The charged air cooler, for cooling the air from the turbo before it goes into the engine, will, on all of the installations, be quite significant. Physically, the size of the thing will dictate the packaging of everybody’s cooling systems. That’s the biggest single thing, I think, that’s presented itself as a challenge in terms of the overall car architecture.
Q: James, do you agree with Mark’s suggestion that cooling is going to be a very important area?
James Key: Oh yes, the cooling requirements are completely different. You’ve got a turbocharger with a charge cooler on it, you’ve got a much larger energy recovery system (ERS) which naturally pumps out more heat, and you’ve still got your gearbox, hydraulics, oil and water to cool, so you’ve got a completely different situation to what we’re used to. You want to package that in the tidiest way you can. There are new technologies involved in all of this - it’s not stuff you can carry over.
There are other challenges too: the weight limit is higher than now, but it’s tight. It sounds a bit trivial but it’s not at all; it’s a big challenge - there is a lot of stuff on the car.
I think the installation of the power unit and the rest of the bits that go with it provide another challenge. You’ve also got to select eight gear ratios that will do the job at all of the circuits - that’s pretty tricky when you’ve got a different power unit and different aerodynamics. How do you predict that accurately? You’ve got to go through and make sure that you understand if there are any sensitivities that you need to look out for.
The final big challenge is getting the car to work as one coherent unit - not as separate systems. What’s been most noticeable to me is that the interdependency between the different parts of the car is far greater on the 2014 car than today. The way you lay something out, or the way you install something, or the way something operates has a bigger knock-on effect on other areas than is the case now. Take for example the engine installation: there’s an aerodynamic implication, there’s a gearbox design implication, there’s a chassis implication - everything is much more interrelated than we’re used to.
Q: So does that mean the cars could look quite different to the way they do now?
MS: It’s all relative. Will they look significantly different to people who don’t follow the subtleties of the sport? Perhaps not. But it’s honestly difficult to know. I think we’re trying to resist having to make significant changes that will affect the external appearance of the car because of what we’re trying to do aerodynamically, but we’re fighting a little bit of a losing battle.
I wouldn’t’ be surprised if we did end up with a few solutions that are a bit different because the challenge of just packaging the size of cooling systems that are on the car is quite extreme.
Q: Okay, so given a ‘clean sheet of paper’, do you think we’ll see more variation in car designs?
JK: I think there are probably two parts to that. Yes, the current cars do look quite similar to each other, but the performance range across the grid is still quite big, so there are significant differences in the way the cars are working.
There’s a lot of increased complexity under the skin of cars nowadays - more subtle things that aren’t’ so obvious when you look at them - that can make a difference. I think that will continue.
It’s a tighter set of regulations, but I think that drives innovation. Look at the amount of innovation that’s occurred since the last set of significant aerodynamic changes in 2009 - we’ve seen F-ducts, double diffusers, blown diffusers, and all that stuff has happened since then because you are restricted from taking the normal steps that you would take.
When we started in 2009 - which is a good analogy for 2014 - generally, most of the teams had similar looking cars and the grid was closer than expected. That’s where the innovation had to come in to break away from that. I suspect it will be the same in 2014.
Whether that happens straight away or whether it develops I don’t know, but I think there will be some clever ideas and interpretations.
Q: At the moment, F1 racing is a very aero-driven formula. Do you think it will shift slightly so there’s more variety?
JK: I certainly think it’ll be more of an engine formula than it has been. I think there’s more diversity for the engine manufacturers to produce performance. Because of the ERS and the way you can recover energy, a lot of different solutions are going to be looked at and there is lots of optimisation to be done. So it will be more of an engine formula, but I still think there will be a very heavy aerodynamic effect on relative performance.
MS: My own view has been that for a number of years, the pecking order is determined by the tyres, then aero, then drivers, then engines. I think that what we’re going to see is that the easiest way to bolt on or take off performance is the tyre manufacturer making a change to the tyres.
The biggest thing that the chassis guys have got within their control is still the aerodynamics, but there is a greater role to be played by the power unit now, for sure. It’s going to be a massively interesting challenge in terms of ‘we’ve got this chunk of energy - how can we use that over a certain period of time in an optimum fashion?’
Every time we have discussions with the engine people to look at next year’s power units, it’s almost a computer software game: how do you best use the combination of the two ERS with the energy storage and the internal combustion engine? How do you put all of that together in an optimum fashion with a limited amount of fuel to get your optimum performance? The opportunity to get that wrong and make a mistake is potentially quite high.
I think that certainly for the early part of the 2014 season that will be very interesting to watch. Therefore, it’s my feeling that the role that the power unit will play will be more interesting.
Q: So can you explain how and when you get started on a project like this?
JK: I originally started looking at it with my old team (Sauber) when the regulations were developing - so that would have been at the end of 2011. Really I think that’s the period where you need to start thinking about the implications of such a massive change, particularly how your basic understanding of the car changes.
When I arrived at STR (Scuderia Toro Rosso, in September 2012) not so much had been done. Obviously there was the engine question as well, so it was a case of starting as soon as possible.
MS: For us, it was around March last year that we first started to have someone look at an overall layout of the car.
With such a sweeping regulation change, the first thing is to assign a small project team to thoroughly analyse the regulations as they exist at the time; understand the implications of those regulations in aerodynamic, mechanical and vehicle dynamic respects as best possible; then start to put down some basic lines in the sand in terms of wheelbase, engine length, gearbox length, fuel cell requirement etc.
Then we’re able to start fleshing out that basic backbone of the car with the narrower front wing concept, the shallower window for the rear wing and the way things like turning vanes might be implicated by the new regulations.
You start to look at the impact of that in CFD (Computational Fluid Dynamics). Obviously then people start preparing the basics for the wind tunnel model.
JK: For a team the size of ours, you need to try and very carefully split your resource.
Clearly with the 2013 car arriving and hitting the track in February, there’s a huge amount of resource tied up in that. We had to split off areas of various departments to begin to work in parallel in certain aspects of the car, again to re-establish that understanding of the philosophy you need to pursue.
In one case we had to look at engine installation and what the implications of that were. On the aero side - which is the other big part of this regulation change - we had to get that underway and start looking at a) what the effects are and b) how we’re going to approach it. What sort of clever ideas and loopholes there might be - they are the bread and butter of getting performance on the car.
Q: Will the switching of resources from 2013 to 2014 happen earlier this year?
JK: Yes it will. It’s a difficult balance. You want to leave it as late as possible because the flyaway Grands Prix at the end of the year represent a third of the season and they’re all as important as the first races.
So it’s a difficult split - you need to have a strategy that allows you to support the 2013 car, but you need to prioritise under the circumstances we’re in now, and you need to focus on the stuff which is going to give you the best return to make sure you maximise what you’re doing.
There are certain areas of the 2013 car that you’d love to look at but you can’t, and there are certain areas that won’t be touched now because we have to move on. If you can prioritise and say ‘we’ve got 10 things to look at, let’s look at these five’, that kind of alleviates some of the pressure of trying to work full on with the current car to the detriment of the future car.
Q: Finally, as technically-minded people, is a step-change in regulations daunting or is it something you embrace?
JK: There’s always concern there because your performance is relative. You think you’ve done a great job and then someone pops up with something…
You’ve got no benchmark - if you’re going from one year to the next with stable regulations, you know what you’ve got to achieve to affect a step forward.
Here there’s no benchmark at all. You’re kind of thinking ‘we’re going to set some ambitious targets, let’s hope they’re high enough, but not so high that they’re impossible to achieve and people get demoralised.’
So there is a concern there that you might have missed something, but I think that’s far smaller than the enjoyment of the technical challenge and thinking what you can, as a team, put into a new car in terms of new ideas.
MS: I find it exciting. When the regulations remain fairly static there are two ways of looking at it. As a relatively young team, we’re kind of starting to find things out and our rate of development has been quite good. So there’s a little bit of frustration that the regulations are now changing just as we’re kind of finding our feet.
But on the other hand, from a technical challenge perspective, it’s very interesting. So much of it is different that you are having to think from scratch, and in many areas, from a blank piece of paper.
So purely from an engineering perspective it’s quite exciting. I think it’s going to be a more balanced formula, rather than just being dominated by aerodynamics. That’s been the criticism for a while.
In terms of the input that the engine manufacturers put into the sport, they now have more than a stake. Whether it changes my pecking order - if my pecking order is right - or whether it just changes the emphasis, I don’t know.
Source: http://www.formula1.com/news/features/2013/8/14875.html
WhiteBlue
92
Nice summary and interview, unfortunately the guys cannot be very specific.
