ringo wrote: ..... I think the MGUK torque figure is the elephant in the room when limiting these new f1 motors.
Also it may be the reason mercedes are requesting wider tyres. That 250NM will be right off starting speed for that motor so you can imagine coupling this to the turbo engine's torque, which by itself is greater than the V8.
As for the 15,000rpm rev limit, let's see what the teams do.
what the EM could do 'right off starting speed' is immaterial and illusory
the EM could only do this if allowed to draw a correspondingly huge current (attempting to give huge/infinite acceleration)
roughly the job that our car starter motors do (when allowed to draw freely from a charged battery)
the 2014 EM will be energised from a drive where the current is always managed (that's what varying the voltage does)
managed so as not to need the drive to be the size of Texas
the EM/MGs size,weight,bulk and responsiveness are related to mean (more like rms really) torque
(so giving them apparently 'free' peak torques in motoring and generating that can and will be temporarily much greater)
their 'drives' size,weight bulk and responsiveness are strongly related to peak torque
so the penalty for the electric machines 'free' peaks is paid by the drive side
the cars will be designed for best through-race performance (ie compromises) not for best 1000 ft dragstrip performance
the EM torque will be limited by the rules to a fixed proportion of ICE torque at all times anyway ?
yes, rpms towards 15000 require much less supercharger power, as your calcs showed us a long time ago
low boost and relatively high rpm works well (for crankshaft power under fuel-efficiency rules)
but 2014 will have super-high-Octane 'petrol' (as well as super-DI) so can stand high boost
IMO this allows higher backpressure and higher exhaust recovery (raising efficiency by reducing pressure/KE loss in blowdown)
IMO even with engine running based on 10500, the gearboxes will have them going eg to 12500 significantly
so below 10500 is interesting, but above 10500 is more important because that's where the fuel is
