agree.. motorsport wants clicks!RZS10 wrote: ↑06 Nov 2019, 17:13When the motorsport network doesn't run the same story on all their sites you know that it's catered to a certain audience ........
I guess this is the video polite mentioned
https://it.motorsport.com/f1/news/repor ... /4593121/
If they believed there was actually anything to the story they'd have articles or videos about it on at least several of those sites
https://i.imgur.com/S5GbR2M.png
There is absolutely nothing about that topic on any of them apart from the italian one ... lol
Polite wrote: ↑06 Nov 2019, 16:32not an article but a video review of the USA gp..LM10 wrote: ↑06 Nov 2019, 15:58Can you link that motorsport article please?Polite wrote: ↑06 Nov 2019, 12:15
maybe.. or Mercedes gives them informations on the Ferrari PU (Sassi and Allison... for years now did that, but Mercedes doesnt want to be the one protesting to fia)
rumors from motorsport.it: Honda involved in a spy story, their ICE is a copy of the Ferrari one.. also they tried to cheat on the fuel flow this season, several times, till the RaceDirection asked em to stop (noone here remember the story of the pressure of the injection system? was against Honda.. but everyone here thinking it was for Ferrari )..
"A tenere banco è anche la polemica innescata da Verstappen sul motore della Ferrari, ma a quanto pare anche Honda non sarebbe esente da "inchieste""
"The controversy triggered by Verstappen on the Ferrari engine is the main theme, but apparently even Honda would not be exempt from inquiries"
then in the video they say that the honda ICE is so similar to the Ferrari one that cannot be fortuity and the focus is the motorhead!
SORRY for not linking the site...
https://it.motorsport.com/f1/news/repor ... a/4593121/ this
Yes, stabilizing the frequency and phase of the peaks per se is fairly unproblematic, at least in principle, but how would you propose (hypothetically, of course) to control the _relative_ phase of flow peaks vs FFM measurements? If your proposal involved a U/S detector, we would be back into the first reply of mine.Mudflap wrote: ↑06 Nov 2019, 00:19I think there's a more practical way of doing it (obviously I am arguing purely for the sake of it and because I find it interesting - I am in no way implying that any team does it).ncx wrote: ↑05 Nov 2019, 18:04That's surely a more interesting conjecture than the one on the invisible fuel cache or the one on the nearby electric cable that can alter the flow-meter function without causing noticeably anomalous readings.Mudflap wrote: ↑03 Nov 2019, 02:07It should be possible to alias the sensor measurement if they can somehow produce a high enough frequency pulsation.
The low pressure pumps are usually electrically driven gear pumps so they would produce pulses at tooth pass frequency. Given a high enough pump speed and number of teeth it could be achievable.
For example a gear with 13 teeth spinning at 10000 RPM would produce pulses close to the 2 kHz sampling frequency MM mentioned earlier.
The pump motor could be controlled to produce the desired frequency and phase angle such that the flow sensor never samples the flow peaks.
In order to anti-synchronize the flow illegal peaks against the measurements, they would need to detect the ultrasound impulses and modulate the pump accordingly, using a sensor for the sensor (so to speak) which should pass unnoticed through scrutineering together with the relative electronics and software, and the whole secret system should work almost perfectly on a sub-millisecond time-scale. Even if the time intervals between measurements were always exactly equal (no drift, no thermal effects, etc) and that therefore the system would have to be fine-tuned only occasionally during the race, it is imo quite unlikely to be feasible, especially considering that the movement of mechanical parts is involved.
One could simply "calibrate" the pumps by running the engine at a known operating point (let's say 95 kg/h) and then just slightly tune the phase angle. Adjusting the phase angle in one direction would cause an increase in FFM measurement (even though the operating point and hence real fuel flow is unchanged) while going the other way would cause the reading to decrease. Such calibration could probably be built into a closed loop control system that ensures the frequency and phase never drift too far.
This way all that is really required is that the real fuel flow rate is very well mapped for the entire range of engine operating conditions which isn't such an unlikely proposition.
There's also multiple ways of creating the 2kHz pulses - abrupt diameter changes, PRV flutter, etc but I proposed the electrical gear pump since it offers the simplest way of controlling the phase angle.
the 100kg/h is a measure to cap horsepower and probably to reduce spending outlets. Without it, teams would definitely run 15,000RPM.Mattchu wrote: ↑06 Nov 2019, 17:26I have a question that hopefully one of the resident engine gurus could answer (GG, Mudflap, wuzak, dans, etc)
With all the furore surrounding the recent TD and the possible affects it had on the Ferrari PU and specifically on the measurement of fuel flow, what would likely be the maximum/optimum fuel flow in the ICE`s that Formula 1 is using at the moment?
Obviously as the engine is limited to 1.6 litres, the rpm is also limited and the amount of fuel allowed to be used per race is limited there must be a theoretical cut off point [efficiency accounted for]. Why do we have a need for the fuel flow sensor/meter. Couldn`t they just say, you have x amount of fuel for the race [with x litres left at the end for testing], use that how you see fit...
Or am I missing something blindingly obvious?
Cheers,
p.s. I don`t think this is how Ferrari have a better PU, I still think they have a better MGUH system than anyone else!
As far as I know in a turbo engine without maximum air pressure limit (as actual F1 rules) you need a fuel flow limit to avoid having a lot more power in qualification mode and overtake one.Mattchu wrote: ↑06 Nov 2019, 17:26I have a question that hopefully one of the resident engine gurus could answer (GG, Mudflap, wuzak, dans, etc)
Cheers,
This poorly written article (rather rant/blogpost) by the former Ferrari press officer is nothing but polemics, rumours, accusations and opinion making - not exactly a reliable source, is it?Polite wrote: ↑06 Nov 2019, 17:20but also on formulapassion.it article by Alberto Antonini
https://www.formulapassion.it/motorspor ... 65651.html
.. a lot of informations about those honda's attempt to cheat on the fuel flow and/or the likkage of oil from the ers cooling system.
How do you judge this one:RZS10 wrote: ↑06 Nov 2019, 17:49This poorly written article (rather rant/blogpost) by the former Ferrari press officer is nothing but polemics, rumours, accusations and opinion making - not exactly a reliable source, is it?Polite wrote: ↑06 Nov 2019, 17:20but also on formulapassion.it article by Alberto Antonini
Gilles27Kimi7 wrote: ↑05 Nov 2019, 15:21Meanwhile, while by no any means conclusive, we have some data:
https://f1ingenerale.com/?attachment_id=97413
https://f1ingenerale.com/?attachment_id=97412
https://f1ingenerale.com/f1-power-unit- ... -qualcosa/
OhhXwang wrote: ↑06 Nov 2019, 17:51
https://www.motorsport.com/f1/news/ferr ... a/4593473/
(IMHO it is nothing but polemics, rumours, accusations and opinion making - not exactly a reliable source, but with opposite view than Antonini's one).
Where is the truth?
Maybe it is important to understand which are the shitty-sources, do you agree?nzjrs wrote: ↑06 Nov 2019, 17:55OhhXwang wrote: ↑06 Nov 2019, 17:51
Where is the truth?![]()
the thread was going so well with a nice technical discussion of the possible weaknesses of the fuel sensor. Are we going to play shitty-sources-ping-pong now?
ofc, marko's, max's and toto's are reliable more than a journalistRZS10 wrote: ↑06 Nov 2019, 17:49This poorly written article (rather rant/blogpost) by the former Ferrari press officer is nothing but polemics, rumours, accusations and opinion making - not exactly a reliable source, is it?Polite wrote: ↑06 Nov 2019, 17:20but also on formulapassion.it article by Alberto Antonini
The are trying to push the manufactures into making higher efficiency engines.
