Juzh wrote:SectorOne wrote:the Mercedes looks so good in the high speed corners it´s insane. Front end just sticks and the rear end just deals with it.
2012 pole - 24.922
2015 pole - 26.327
They are not that far off the V8 days now, but we´ll have to see a couple more dry races to get a better picture.
2012 was a slow year
2011 23.5
2010 24.0
But yeah, they're getting there slowly.
Remember though that in 2011 - 2012 they had free use of DRS in qualifying (in any corner), which may equate to 8 tenths per lap or so. They also had super EBD with off-throttle in 2010 - 2011 (double-diffuser in 2010), still reduced EBD in 2012. Then they had the beam wing, and wider front-wings for more front downforce. You then have to consider that these new cars are much heavier - I believe about 1.5 - 2 secs per lap slower due to weight compared with 2013. They tyres have been made more conservative and slower to cope with the torque of these new engines.
If you consider all of this it's pretty remarkable, the times they're doing. Imagine however a car with the current V6 (Merc) engine, with a double diffuser, exhaust blown diffuser, off-throttle mappings, beam wing, and free use of DRS in qualifying. That would be a true beast!
Also what's a little surprising is that normally you would expect the field to get tighter after the 1st year of new regulations - what has actually happened is much bigger gaps. Large gap from Merc -> Williams/Ferrari -> RB/Torro Rosso/Lotus -> rest -> Manor (really?) -> Mclaren...
