Ferrari SF23
Re: Ferrari SF23
Instead of the constant radius of the 2022 wing this one has a flatter center section.
Venturiation
Venturiation
98
Re: Ferrari SF23
did anyone listen to Pat Symonds yesterday saying he was surprised by the Ferrari porpoising by looking at the data he had access to, he said after one year and rules changes it should have been under control
Re: Ferrari SF23
Venturiation wrote:
25 Feb 2023, 13:20
They were testing setup extremes to define limits for themselves according to what the drivers have said. The way the car was on Thursday Leclerc said he completely expected it
Re: Ferrari SF23
ryaan2904 wrote:
25 Feb 2023, 14:17
Is the sf23 inherently understeery? Also today press conference charles said the car characteristics have changed this year. They've gained top speed but lost downforce, atleast compared to redbull.
Doesnt look good.
For the 523564396th time - Ferrari are testing with less downforce than Bahrain's Sakhir circuit requires. It's not an indication of any kind of behaviour
sbrillo
sbrillo
Re: Ferrari SF23
ryaan2904 wrote:
25 Feb 2023, 14:17
Doesnt look good.
he didn't said that they lost downforce!
Re: Ferrari SF23
The low downforce wing is likely testing for Jeddah.
A lion must kill its prey.
chrisc90
Re: Ferrari SF23
Can downforce not come from other areas such as the beam wing of rear floor/diffuser? hence the ability to run a smaller rear wing to reduce drag? Since the downforce comes from other areas rather than just the rear wing?
Re: Ferrari SF23
chrisc90 wrote:
25 Feb 2023, 15:51
They are also running a low downforce beamwing configuration (the same used at Spa last year)
ryaan2904
ryaan2904
36
Re: Ferrari SF23
Vanja #66 wrote:
25 Feb 2023, 14:26
ryaan2904 wrote:
25 Feb 2023, 14:17
Doesnt look good.
Yes, you are right. These 2 days have been quite different from what ferrari has done during testing in the past few years.
CFD Eyes of Sauron
jumpingfish
Re: Ferrari SF23
hollus wrote:
24 Feb 2023, 19:51
A reminder to everyone but specially to the new people (welcome!).
The car threads are specially strictly moderated in this forum. Stick to this car and to hardware in the car threads.
Team politics and other team things, please in the team threads.
Lap times and will they be faster/slower than XYZ, either in the team threads, in the testing thread or in the race threads.
If your post is in this thread and is not centering on this car, the physical car, it might have been or might be deleted or moved.
Let's keep the awesome car threads on this forum
a) focused on the hardware and
b) awesome.
Thanks.
Andi76
Andi76
428
Re: Ferrari SF23
ryaan2904 wrote:
25 Feb 2023, 14:17
Doesnt look good.
As some have already mentioned, Ferrari drives with a rear wing with much less downforce than would be appropriate for Bahrain. Of course, this has corresponding consequences. Therefore, of course, any comparison is difficult as far as that is concerned. However, it's certainly not negative that Ferrari still sets acceptable times and is probably the second fastest car in these tests, because the lack of downforce means you lose lap time in any case. You also have to consider that Ferrari has made massive changes to both suspensions in terms of suspension geometry, so you're almost starting from scratch in terms of set-up. And it is a very complex and tedious matter to find a good or basic set-up, especially as far as the dampers are concerned. So there's practically twice the performance hidden here that you can't see yet. What is rather worrying are Leclerc's comments that he has experimented with different driving styles, which makes it clear that the car has changed significantly in terms of balance and is probably not optimal. Of course, this also has a lot to do with the set-up. It does seem that the SF-23 has a tendency to understeer, as Sainz seems to cope better with it. In a way, this would be logical, since Ferrari realized many years ago that cars with a slight tendency to understeer are gentler on the tires. Therefore, it might actually be a development goal for the SF-23 to achieve exactly this tendency. But all in all, there is certainly still a lot of power in the SF-23, which is contesting the tests with a rear wing with too little downforce and completely new suspensions, as well as a completely changed thermalem management as far as the tires are concerned.
Seanspeed
Seanspeed
Re: Ferrari SF23
25 Feb 2023, 15:51
Yea, their beamwing is noticeably less cranked compared to most all other cars out there during this test:
f300v10
f300v10
185
Re: Ferrari SF23
Even the new single pylon wing tested this morning was using small beam wings:
hollus
Re: Ferrari SF23
Sorry for the temporary lock, guys. I locked it to clean up and forgot to re-open it.
Re-opened now
Rivals, not enemies.
Re: Ferrari SF23
#Ferrari changed the bottom on Carlos Sainz for the last run
Visible modification with the short tie rod already seen at Fiorano, not visible the modification under the bottom
The new floor DID materialize but it does not seem to be a large difference
