scarbs wrote:The MP4-25 follows more of Brawns lead than the expected Red Bull philosophy. Following brawns lead last year with a relatively low nose, even placing their steering rack down inline with the lower wishbones. but then taking a cue from the Williams by having a snow plough under the nose. Although Brawn did have their own take on this device mounted above their splitter. Surprisingly there’s no Newey “V” nose.
The front wing was based on the one seen in testing late last year, with some added fences between the mandatory neutral central section and the four element ‘downforce’ producing outer portions.
The sidepods follow McLaren’s recent practice with inlets mounted high above a deep undercut, this year the inlets are rectangular section. The sidepods then drop sharply exposing the vast curvaceous fuel tank.
McLaren has shrunken the sidepods by raising the exhaust system into its own bulge and exiting high above the gearbox, this area probably also vents some of the hot radiator air, allowing the rear portion of the coke bottle shape to be extra thin. A shark fin has been added so a little Red Bull influence does exist.
You are most definitely better informed than me, but is the McLaren nose really "relatively low"? Looks relatively high to me, certainly higher than the Ferrari when comparing the side shots, especially the lower edge of the nose which remains higher on the McLaren over the length of the nose beyond the bulkhead.
Could it be that the Newey V nose would interfere with the airflow from the front snowplow to the underside of the car?
