I'm not sure if it was already mentioned:
The load for the FiA tests is applied at a point 800mm forward the front wheel centre line. This means if you make the front wing mounting exactly 800m forward the front wheel centre line the leverage is minimized. So you can make a less stiff wing which can rotate more.
For example:
1)if you make the front wing mountings 750mm forward the front wheel centre line the load will have a 50mm lever -> you have to build a stiffer front wing
2)if you make the front wing mountings 800mm forward the front wheel centre line the load will have no lever -> you're mounting could be made of a very soft material nevertheless the front wing will be declare legal.
Is it true or should I stop writing posts after 2:00 am?
if I understand the last page of the
Technical Regulations correctly the central piece of the front wing reaches from 750mm to 999mm forward the front wheel centre line.
(and i'm not sure if lever and leverage is the right word. sorry if not
