568
Re: A shameless thread for the enginephiles
xpensive wrote:
marcush. wrote:so Porsche calling their engines Boxer but really this is wrong naming ...nitpicky as Germans are this is outright scandalous.. :mrgreen: :mrgreen:
And the same goes for those Italian F1 engines, they were all 180 degree V12s and not Boxers, this is an outrage!
You mean the Berlinetta Boxer was not a . . . . . "Boxer"? Outrageous indeed!!
xpensive
xpensive
214
There you go grunts, I can see lawsuits on the horizon...! :evil:
469
I have a vague recollection that the Alfa Romeo flat 12 was a boxer. I haven't found anything that shows whether it was or not.
Does anybody know about this engine?
xpensive
xpensive
214
There's no way wuz, a true 12 cylinder "Boxer", according to Felix' definition anyway, would be a mile long.
Sombrero
Sombrero
126
-Felix-
-Felix-
xpensive wrote:There's no way wuz, a true 12 cylinder "Boxer", according to Felix' definition anyway, would be a mile long.
How dare you, I did not say that! It would be at least 1.327 miles long!
xpensive
xpensive
214
Porsche's (or is it a Subaru?) true Boxer 6, imagine two of these wuz?
469
xpensive wrote:Porsche's (or is it a Subaru?) true Boxer 6, imagine two of these wuz?
http://cars.natemichals.com/wp-content/ ... e_911a.jpg
My recollection is that the Alfa flat 12 was quite a bit longer than the Ferrari flat 12.
But my memory could be faulty....
xpensive
xpensive
214
A 12-crank crankshaft, I doubt is, not even Porsche tried that as Felix pointed out?
But I wonder if this was a true Boxer, looks like it from the staggered cylinders?
469
Staggered cylinders would also be made when two rods are on the same crank pin.
Edit: I've changed my mind - I don't think that is a boxer.
469
The Alf certainly doesn't look liek a boxer in the cutaway
Whereas the Alfasud is
xpensive
xpensive
214
Great images wuz, I do belive the Porsche 8 is a Boxer, dramatic staggering, the Alfa 12 is interesting for other reasons.
The central cam-drive and twin ignition-units, but are you certain this is the 70s engine, You might have it confused with this?
The never raced 4WD 1954 Alfa Romeo 160
-Felix-
-Felix-
Yes, except the 912 all other porsche flat engines were "real boxers" ;)
568
Flat 12 has basically the same balance as an inline 6 ie good - although looking at the cutaways the Alfa seems to have 30 deg crankpin phasing (inline six = 60 degree phasing). The Porsche OTOH looks to have 60 deg phasing.
648
not an issue for (resultant) balance, 'just' a detail of crankshaft design that can govern main bearing count and engine size/weight
8 cylinders or less has almost never been a 180 deg V, because the balance would then be as bad as an inline 4 (or 3 or twin etc)
the 2 litre Tecno, said ex ? , was an example of the 180 deg V 8
the 1952ish Anderson F2 180 deg V 8 had 2 main bearings (an 8 cylinder 'boxer' might need 9 main bearings eg the 1962 Porsche F1)
the 12 cylinder 180 deg V (non-boxer boxer) can have fewer than 7 main bearings unless it's too long (eg due to air cooling- Porsche)
ie the trend-setting and dominant (1970s) 180 deg V 12 cyl Ferrari F1 'boxer' had 4 main bearings - that was a big point
presumably Alfa emulated this feature in their 70s (flat 12) race engines ?
not in the 1950s Tipo 160 (derived from the 1940s secret 512 ?, and maybe over-cautious in bearing matters and so in length)
the tipo 160 car (an incomplete project) had a cast structure, 4 wd, and front mid-engine (driver's seat behind rear axle line)
the seating position was tried by modifying a 159 and worked well, presumably due to better weight distribution and traction
