Moose wrote:That said, the "by debris" bit is the bit I'm not completely sure of. We've had a bunch of people asserting that their tires have appeared to be cut after runs. Could it be that certain high speed & downforce circuits (Spa, Silverstone, Korea, Japan) load the tires in a certain way, and that that can cause the rubber to split? That would explain a whole lot of failures that the Pirellis have at generally similar types of circuit.
Think you're being a bit naive there Moose old chap. 'Cut by debris' is a very wide ranging statement and is vague enough to cover any eventuality. Don't forget, every tyre at Silverstone 2013, was allegedly 'cut by debris/kerbs'...
