McLaren MCL38
f1rules
f1rules
612
Re: McLaren MCL38
I can see people saying he probably meant during winter so i dont know why they posted this qoute, sorry i cant delete now
Luscion
Luscion
105
Re: McLaren MCL38
f1rules
f1rules
612
Re: McLaren MCL38
Ok what car did they show yesterday, everything is new
Luscion
Luscion
105
Re: McLaren MCL38
f1rules wrote:
03 May 2024, 16:05
Looks like they put the old spec car together and then added the new parts this morning, seems like Merc did the same thing
Emag
Emag
105
Re: McLaren MCL38
Wow okay, that's a big package. The car they assembled yesterday is not the upgraded one then, because that looks exactly like the car which left China. They might try to run old spec vs new spec on the only practice session they get, but it's a bit unfortunate for Oscar because he won't have too much time to adapt to the new package before sprint quali starts.
Developer of F1InsightsHub
Ground Effect
Ground Effect
Re: McLaren MCL38
LionsHeart
LionsHeart
Re: McLaren MCL38
f1rules
f1rules
612
Re: McLaren MCL38
F5 F5 F5 F5 .......
CjC
CjC
Re: McLaren MCL38
And that’s supposedly ‘part’ of the update package??
Just a fan's point of view
sjy1969
sjy1969
Re: McLaren MCL38
CjC wrote:
03 May 2024, 16:15
That’s what I was thinking!
Edit: Does the diffuser count as part of the floor? If it does then I’m struggling to see what is still to come for Imola apart from the rear wing.
LionsHeart
LionsHeart
Re: McLaren MCL38
CjC wrote:
03 May 2024, 16:15
Yes, this is just 30% updates :D
mwillems
45
Re: McLaren MCL38
Most of the changes won't add time, they are simply to let the airflow make its way correctly around the car. The volume of changes won't inform the laptime gain.
Most of the important work is around conditioning the flow at the front and how the floor uses it. Front and rear geometry changes are to stop the airflow being impeded. Same with front corner and the inlet. Engine cover is about the flow to the rear.
Two things here are to generate time. The wing and the floor. The rest is largely about retaining flow through and around the car.
After 18 months I can finally stop banging on about the front of the car conditioning the air!! 🤣🤣🤣
-Bandit
mwillems
45
Re: McLaren MCL38
LionsHeart wrote:
03 May 2024, 16:22
CjC wrote:
03 May 2024, 16:15
Imola has been confirmed comfy leather seats and a Bluetooth entertainment kit and some mood lighting.
-Bandit
Dafnalina
Dafnalina
Re: McLaren MCL38
mwillems wrote:
03 May 2024, 16:42
Sorry, could you explain what was the issue with the way the front of the car conditioned the air? What was the effect on the car?
f1rules
f1rules
612
Re: McLaren MCL38
still not obvious
