Mercedes has reinvented an F-duct style innovation and intends to debut it in 2012, Germany’s Auto Motor und Sport reports.
The magazine on Tuesday published diagrams of the innovation, which was apparently tested for the first time during free practice at Suzuka recently.
The new F-duct is confined to the front wing, not the rear wing as per the systems that were banned at the end of last season.
Air enters through the oval-shaped vent at the very tip of the 2012 Mercedes nose, is redirected via and inside the front wing supports and exits at the rear of the wing.
Unlike the 2010-style F-ducts, the system is not manually triggered by the drivers, making it legal.
Mercedes’ new idea is to redirect more undisturbed air through the floor of the car.
Auto Motor und Sport said McLaren boss Martin Whitmarsh is aware of the innovation and the head-start now enjoyed by Mercedes.
“If you make a start now, it’s already too late,” he said, predicting that other teams will nonetheless also experiment with the idea.
High res:marcush. wrote:picture of gearbox and rocker arrangement
I guess that's just for cooling after they lost the whole on the nose.Holm86 wrote:Mercedes had a passive F-duct rear wing last year before the could make it active.
Perhaps this extra intake on top of the W02's nose has something to do with this??
I'm unaware of this, could you elaborate a little or give a link or two? Sorry, I've been out of it of late.Mr.S wrote:Nice. New rear suspension,talk of the bagpipe exhaust being tested in Hungary & now this F-duct. All might help for next year.
Impressed with Bob Bell,debuted new wing & rear-ward exhaust & minor positive changes without much fuss. Earlier Ross Brawn used to advertise every small update as something historical. Now Bob does his job without any noise.
Very impressed by Bob,slow steady improvements. Mercedes have made a fantastic acquisition in Bob Bell.
Furthermore because it is an interchangable part of the car, you could use custom designed wings on a track-by-track basis to only stall above the v-max of the fastest corner on that given track.Shrieker wrote:The great thing with McLaren's f-duct was that there were no moving mechanical parts yet the reasoning was done by a human being,ie a driver plugging a hole (pardon the punbeelsebob wrote:Haha, touchéShrieker wrote:Which would be perfect while going through fast corners) whenever he wanted to.
But you could still configure it(Mercedes' front wing) to stall only in very high speeds -say- above 300-310 km/h, there aren't many corners in F1 taken above those speeds (if any), so it would still give some kind of an advantage. So all is not lost.
But that does not get over the fact that it cannot be used in 2012. And they are hardly developing it for the last two races of 2011, are they?Mr.S wrote:Well it was reported from several sources that Mercedes have found a simpler solution to Mclaren's octupus exhaust & they have tested it in Germany & have found that it gives better downforce than the current exhaust system.
forget the f duct!imightbewrong wrote:High res:marcush. wrote:picture of gearbox and rocker arrangement
http://www.formula1.com/wi/sutton/2011/d11kor948.jpg
