Tim.Wright wrote:riff_raff wrote:Engine braking does not add heat load to the brake rotors. This can be significant with a heavy chassis and steel rotors, which may be subject to fade.
What I was talking about has nothing to do with using the engine braking to physically slow the car. Im talking about using the drag torque to apply locking to the diff and stabilise the car. I believe this is the primary use of engine drag torque these days.
You don't want to completely eliminate the engine drag torque (by rev matching, blipping etc) because there will be nothing engaging the diff locking to stabilise the car.
Tim
This would [only] be the case, with an mechanical locking diff using "ramps" on teh power and coast side [ZF type diff].
Not sure if F1 uses these type of diff today. With an hydraulic "clutch pack" powered by a hydraulic system, and ECU/Computer controlled, you could achieve any amount of locking in any phase of the corner, independ of engine drag/drive torque.
IMO it is not "strictly nevessary", as for the OP question, the car would drive/rcae without it, but as other allready said, it can have it's benefits ( and draw backs).
It provides a means to alter/control/change brake bias (brake torque/force distribution) during the braking phase and from corner to corner.
For a high downforce race car [but not only there], this can be an advantage.
With other (reglement related) limiations for systems to do the same thing, it may was just a means to an end.
As others coined the phrase, " a form of rear axle stability control", or rear axle ABS.
I'm pretty sure, today they (F1) use mainly KERS for a similar purpose.
In more conventional forms of racing (manual gearbox) with RWD cars, it can be used to help the cornering in some cases, by using the last downshift (if more the one gear needs to shifted down), to "unsettle" the rear a bit, to help turn in.
On a side note.
I know more then one race/championship winnig driver(s), who when racing FWD Touring cars, clutched during downshift, to make sure that he does not
get any unsettling effects from downshifts (no engine braking wanted).
Thee guys where usualy the once who where the latest of the late brakers, and any form of aditional braking torque, had the potential to make the wheel lock, which in an FWD car, means U/S and losing the line.
With 19" rims,big brakes & relatively small tyres, there was no shortage in stoping
power from the brake package, so you did not need the engine braking to gain overall improvements in braking performance.
It's on of the "horses for courses" things, different people will do it differently, depending on the type of car/bike and racing & perhaps personal preferences/driving styles. I don't think you can come up with an cut&dry yes/no
answer to the OP question.
