Lotus E20 VD
mike
mike
Re: Lotus E20 Renault
too high to be blowing at the diffuser...
FlYiNgIcEmAn
FlYiNgIcEmAn
First draw from Scarb
The Lotus E20 DRS appears to blow the diffuser, then blows over the beam wing when DRS is open.
N12ck
https://twitter.com/ScarbsF1/status/226 ... 60/photo/1
scarbs take on it :D :D :D
what was that about it not blowing over the top of the diffuser?
Budding F1 Engineer
Owen.C93
Owen.C93
177
N12ck wrote:
Owen.C93 wrote:
N12ck wrote:
it is not stalling the rear wing, it is blowing over the top of the diffuser
They could do that 24/7 if they wanted, no need to make a stupidly complex DRS system.
I might be wrong, but it looks like the ducts lead down to the diffuser area
Oh I thought you meant the beam wing exit.
alogoc
alogoc
-10
Craig Scarborough ‏@ScarbsF1
https://p.twimg.com/AyQAPV8CIAAlc2h.jpg
THE F2012!
THE CAR THAN WON 2012 WORLD F1 CHAMPIONSHIP WHIT A TILTED ENGINE!
N12ck
alogoc wrote:Craig Scarborough ‏@ScarbsF1
exactley what I have been saying all along!
Budding F1 Engineer
alogoc
alogoc
-10
The only problem is Grosjean is faster whitout it! it's a waste of money!
THE F2012!
mike
mike
3 pipes????!!?!?!?
and now I dont get how he is losing downforce at low speeds
hammarby88
hammarby88
Owen.C93 wrote:
N12ck wrote:
mike wrote:the wing is at high pressure so when is on normal mode the pressure stops the air from coming up from the holes, when drs opens the pressure is lower since there is only one profile working the air comes up and pushes the air from the top of the profile to the bottom stalling the wing.
Could do both no?
When DRS is closed, the air from the inlets on the rollhoop is blown out the big hole aka longer version of RBR outlet pretty much. When DRS opens ducts opens mercedes style but blows over the diffusor as N12ck said, meaning DRS with better grip. On top of that a third duct is revealed in the main plane rear wing which makes some of the air going trough that large tube from roolhoop go blow up onto the opened DRS flap mean it could stall the main plane slightly AND increase the pressure to the ducts leading to diffusor.
Sounds possible N12ck?
Owen.C93
Owen.C93
177
Well looking at this image I really can't see how it's ducted to the diffuser. There does seem to be one small hole above the starter motor slot that may be ducted but that's tiny compared to the rest of the inlet.
hammarby88
hammarby88
Owen.C93 wrote:Well looking at this image I really can't see how it's ducted to the diffuser. There does seem to be one small hole above the starter motor slot that may be ducted but that's tiny compared to the rest of the inlet.
The endplates go all the way to the floor.
alogoc
alogoc
-10
There is no flow-wizz paint on diffusor,so maybe Scrabs is wrong!
THE F2012!
Huntresa
Huntresa
Air could come via that highlighted area.
Huntresa
Huntresa
double post
mike
mike
hammarby88 wrote:Could do both no?
why would the air go to the diffusor if it has another place to exit?, wounldn't it be easy if..... 1 scoope blows the diffuser RBR style and the other scoop blows the rear wing and it has 2 separate systems?
