Turbof1's point stands. Even in Bahrain 2010, when they were still using the knees for F-duct activation, the bottom was already chopped off. When they switched to hand-switched F-ducts, the wheel already was chopped off at the bottom.siskue2005 wrote:Look closely at the video, the wheel is intact cut off at the bottom that's the first race they raced it...there are many videos and pics you just have to google itturbof1 wrote: Yes, I knew that too (although I was under the impression it came later at the year). However, point still stands that they did not modify the steering for the f-duct, atleast not until Turkey then. Watching from the video, it remained the same steering wheel.
And also they have f-duct switch repositioned to side of cockpit
And I remember scarbs or someone else confirming they cut it off for easy access of f duct switch
One of Hamilton's first actions in the team was to dramatically simplify the wheel – he says he wants to simplify it more next year too.ringo wrote:Hamilton's wheel is much simpler.
I guess as long as it's doing what he wants, it should be ok.
No, it's completely allowed, and in fact required in the technical regs that the car has an accessible reverse gear. What's not allowed is driving the opposite way to the flow of cars on track, unless it's to take yourself out of a dangerous situation.turbof1 wrote:I didn't know F1 cars still have a reverse gear. Wasn't it forbidden to use reverse?
I think Lewis' wheel just looks simpler, it has a neater aspect because the dials only show the current step/click they're on, as opposed to all of them in Nico's case. The number of buttons and dials looks the same to me. Also, the black dials are less noticeable and fade within the carbon fibre background. All in all, nice changes by Lewis, the wheel has the same number of functions but provides an easier overview with less distraction.ringo wrote:Hamilton's wheel is much simpler.
I think they rarely use it because 9/10 times it's faster to just spin the car around in 1st rather than go back through the box to reverse?turbof1 wrote:I didn't know F1 cars still have a reverse gear. Wasn't it forbidden to use reverse?
EDIT: apperently it is mandated to f1 cars to have one. Technical regs:
9.7 Reverse gear :
All cars must have a reverse gear operable any time during the Event by the driver when the engine is running.
What is the point of it though? They never use it.
I imagine it'd be quite useful if you found yourself in the small runoff zones at monaco or singapore. Most of the time, though they tend to go in with enough room to spin round so I see your point!turbof1 wrote:I didn't know F1 cars still have a reverse gear. Wasn't it forbidden to use reverse?
9.7 Reverse gear :
Simple, you're making the mistake of thinking that never and rarely are the same thing. They're not. Lewis reversed at Australia. The reason is to make sure that drivers have the maximum ability to get out of a dangerous situation if they can.turbof1 wrote:I didn't know F1 cars still have a reverse gear. Wasn't it forbidden to use reverse?
9.7 Reverse gear :
