Lotus E22 Renault
Re: Lotus E22 Renault
In red Nose
in Yellow pylon
http://www.newsf1.it
FrukostScones wrote:http://translate.google.de/translate?sl ... ml&act=url
AMuS: Lotus with extreme and uncopyable engine installation
Interesting rumors
Huntresa
Huntresa
Scarbs
OK I understand the Lotus nose now.....
The two tusks are unequal lengths, longer one forms the 9000mm2 tip, the other is also a crash strcuture, both act as Y250 flow conditioners
Matt Somers
Matt Somers
179
It's a variation on the nose we were talking about in the 2014 thread a few weeks back
Matt Somers wrote:Ok decided to draw it anyway for visualization purposes
http://i3.photobucket.com/albums/y62/So ... 1eb2a4.jpg
So the nose structure is defined in green with the lower tooth section extending to meet with the front of the pylon (Pylons shown in aqua) on the right (Pylon is 25mm and the frontal section of the tooth is 58.26mm) this means that at 50mm rear of the tip the Nose section is inserted into the pylon by 20mm to overcome the 9000mm2 in the regulations. (Think of a Dovetail joint etc in woodworking and then have a look at the quick sketch in the top right hand corner of how you can rob surface area from the Pylon)
The other side of the nose (tooth) cannot project into the same area/space as otherwise you have a conflict with the wording of the regulations (centre). Therefore to create symmetry for aero the yellow section depicts the vanity panel.
I still think the crash test is the largest downfall factor in this design, let alone getting around the wording in the regulations that would almost certainly see a clarification issued (if there hasn't been already).
*Obviously bear in mind I haven't gone to the effort of scaling things in the image
CBeck113
CBeck113
51
Exactly, I was looking for that but I couldn't find it.
CMSMJ1
CMSMJ1
^^ that is quality - I hope it works
IMPERATOR REX ANGLORUM
astracrazy
astracrazy
31
interesting how alike the mclaren and this is from above, sidepods/engine cover
timbo
timbo
111
While definitely original, I'm not sure this solution is of much benefit. Not sure if it's a hindrance too, just a different take on the subject.
via Kevin Harlow
madly
madly
Higher res and dark levels corrected to show details in that area.
Nose tusks doesn't look so thin...
If it's REAL rear end then.... =D> =D> =D> !
Central rear wing pylon
roadie
39
Yeah the packaging at the rear looks tight.
Racecar Engineering are reporting:
Racecar Engineering also understands from sources within the team that the E22 has a very clever mechanism for transmitting torque from the power unit to the transmission, which offers much greater performance than others seen by some team suppliers.
http://www.racecar-engineering.com/cars/lotus-e22/
Rushman
Rushman
:wtf:
anzx
anzx
another one
