NathanOlder wrote:Mercedes are fine, Rosbergs engine was 1 more than the team wanted to do and if you were pushing an engine into 1 extra race id imagine Monza would be the last place you would choose to do it.
As for Lewis in Singapore, it was one of thos freak incidents that only every happen once. So I doubt it will happen again.
I wouldnt be too concerned about their reliability.
There was also the first one for Rosberg in Monza which may or may not be usable and may force him to take grid penalties. They are planning to test it in practice in Japan so nice engine failure in practice later in the season is still a possibility. So no, Merc are not fine at all with the engines, Hamilton is because those failures and point losses are not comparable. To add more content
Chester (Lotus) track:
You can't run maximum downforce in Suzuka - as you will end up a little too slow on the straights - so you need to give the driver sufficient downforce to give confidence in the fast twisty bits whilst not clipping their wings down the straights. This is part of the reason why Suzuka is such a driver favourite, as drivers can be absolutely on the limit without the car totally stuck to the ground through maximum downforce. It's not just having sufficient downforce, it's ensuring that this is delivered in a balanced nature. Getting the suspension set-up spot on is essential here too. You need to extract all the grip that's possible from the car.
Reason for small surprises from time to time.
