[MVRC] Mantium Virtual Racecar Challenge 2016
Ft5fTL
26
Re: [MVRC] Mantium Virtual Racecar Challenge 2016
HP-Racing wrote:
Ft5fTL wrote:https://snag.gy/oLRDF1.jpg
Dunno what did i wrong.
Close all the OpenFOAM related windows and check in Oracle VM VirtualBox if the default machine is running. If yes, turn it off and try starting OpenFOAM again.
Did you get any errors from OF_Env_Create?
I did but the screen closed before i could take a screenshot. Should i try to run it again? The guide says run only once.
Mantium Challenge - Pure Power Racing
HP-Racing
HP-Racing
Try running it again.
Alonso Fan
how on earth do I create the default machine in virtual box with a boot2docker.iso? I don't understand, please someone explain...?
edit: sorry, my bad, corrupted installation of openfoam. I reinstalled, ran the shortcut and I see it now :)
SHR Modding
Youtube
Twitter
Discord
Sound Developer for Reiza Studios
Sound Modder for Assetto Corsa
HP-Racing
HP-Racing
Alonso Fan wrote:how on earth do I create the default machine in virtual box with a boot2docker.iso? I don't understand, please someone explain...?
Have you run the OF_env_create shortcut?
Ft5fTL
26
These are the error messages .
HP-Racing
HP-Racing
Ft5fTL wrote:https://snag.gy/SY4mbU.jpg
Try running the shortcut with and without admin rights but check the VM software both with and w/o admin rights if the default machine is running and turn it off if necessary.
CAEdevice
50
Ft5fTL wrote:
SR71 wrote:you joined a virtual challenge that didnt know when to say enough is enough....
we could have continued to grow, but we wanted "more cooling"....
Why are you soo salty about the cooling dude? Race cars needs cooling, and the competition is about race cars.
I agree with Ft5fTL. Cooling simulation is more important than (for example) wheels rotation in a race car.
Is you car complete? I remember some stunning renderings, but I am convinced that my car (not the fastest one), despite being compliant with cooling requirements, is faster than yours without cooling devices.
CAEdevice
50
Ok, WFlow works perfectly: I have the OF case ready to be launched.
Wich is the exact command line to launch "runCase.sh" from the OF1606+ console?
Using the default directory (C:\Users\Matteo) and typing "runCase.sh" I obtain:
Code: Select all
C:\WINDOWS\system32>"C:\Program Files (x86)\ESI\OpenFOAM\1606\Windows\Scripts\of_start_container.exe" -Arguments "C:\Program Files\Docker Toolbox\;C:\Program Files\Git\bin"
Starting "default"...
Machine "default" is already running.
of_plus_1606
[ofuser@default ~]$ runCase.sh
bash: runCase.sh: command not found
[ofuser@default ~]$
LVDH
46
Hi Matteo good work, you are very close.
Just run:
Code: Select all
./runCase.sh
Full points will be awarded from the first race on. Same scheme like last year.
I have updated the post-processing utility for Windows. I did not change version number. Just download the files again and use the new utility.
In case anyone already has had successful runs with the case setup in MantiumWFlow please send the logs. Even good logs will be useful at this point.
I do not think that this cooling discussion will at any point be of any value. The reality for every engineer is that aspects of any product or machine cannot be developed with disregard and isolation to other attributes. Most of the time improvements of one attribute will be at cost of another one. Here is a small link about this:
http://atomictoasters.com/2013/07/design-priority/
CAEdevice
50
LVDH wrote:Hi Matteo good work, you are very close.
Just run:
Code: Select all
./runCase.sh
I still receive the message "command not found", there is something wrong with the virtual machine I can't understand.
HP-Racing
HP-Racing
Just run:
Code: Select all
./runCase.sh
try:
bash runCase.sh
That's how I ran the test case.
LVDH
46
Are you sure that you are in the case folder?
pierlu99
pierlu99
Now, it's time to unveil my new car, the Project 001 :D
Of course this is a camo livery, i will present the official Livery in the next few weeks. I would like to partecipate in the Intro-class, but this car, was built on the 2016 KVRC model, so can I join to the championsip with this car ?
RicME85
52
You will need to sort the cooling as the Intro class isnt compliant with the cooling regs.
cdsavage wrote:
RicME85 wrote:So whats going on with the Intro class? Chris? Machin?
Looks like it won't be offered for round 1, sorry. There's probably not going to be enough time to adapt the supplied parts to the opt2 cooling rules.
Alonso Fan
ok, so I've followed all the instructions, and when I type 'cd mvrc_testCase2share' it says there is no file or directory with that name, despite me unpacking it in the shared folder
any ideas?
SHR Modding
Youtube
Twitter
Discord
