Intake looks a little smaller than last year.Giando wrote: ↑10 Jan 2022, 17:04Isn't the shape of the huge rounded airscoop in the picture of the MCL36 chassis conceptually similar to the one on the Toro Rosso STR12 from 2017? Wasn't that a James Key project, aswell?
That said, the huge intake in that area, suggested me something: maybe to make the largest possible room for the venturi underbody with 2022 regulations, it could be wise to move some of the coolings under the engine cover, like Renault already did with their 'elephant' bodywork last year... would that be a possible pattern for this season's cars?
It’s a possibility… Although, the 2022 intake opening is smaller (slimmer) than the 2021 intake, so I don’t think it’s a sign of any major changes in their cooling layoutGiando wrote: ↑10 Jan 2022, 17:04Isn't the shape of the huge rounded airscoop in the picture of the MCL36 chassis conceptually similar to the one on the Toro Rosso STR12 from 2017? Wasn't that a James Key project, aswell?
Why that seems much bigger to me, ahah?SmallSoldier wrote: ↑10 Jan 2022, 17:11It’s a possibility… Although, the 2022 intake opening is smaller (slimmer) than the 2021 intake, so I don’t think it’s a sign of any major changes in their cooling layoutGiando wrote: ↑10 Jan 2022, 17:04Isn't the shape of the huge rounded airscoop in the picture of the MCL36 chassis conceptually similar to the one on the Toro Rosso STR12 from 2017? Wasn't that a James Key project, aswell?
If you use the impact bars in the roll hoop as a reference, the picture in the link seems to indicate that the intake opening is slimmer (less width), potentially a bit taller than the current one, but apparently smaller overall:Giando wrote: ↑10 Jan 2022, 17:14Why that seems much bigger to me, ahah?SmallSoldier wrote: ↑10 Jan 2022, 17:11It’s a possibility… Although, the 2022 intake opening is smaller (slimmer) than the 2021 intake, so I don’t think it’s a sign of any major changes in their cooling layoutGiando wrote: ↑10 Jan 2022, 17:04Isn't the shape of the huge rounded airscoop in the picture of the MCL36 chassis conceptually similar to the one on the Toro Rosso STR12 from 2017? Wasn't that a James Key project, aswell?
That said, the huge intake in that area, suggested me something: maybe to make the largest possible room for the venturi underbody with 2022 regulations, it could be wise to move some of the coolings under the engine cover, like Renault already did with their 'elephant' bodywork last year... would that be a possible pattern for this season's cars?![]()
It's conceptually more similar to the 2021 MCL airscoop, which is inspired by the Merc airscoop. Merc was one of the first teams to use this specific design (2016), the triangle inside an ellipse... the triangle being the real metallic roll-hoop, while the ellipse is carbon fiber bodywork. The triangle feeding the engine, while the half circles feed the radiators.
SmallSoldier wrote: ↑08 Jan 2022, 00:11Roll hoop slimmer than in the MCL35M and seemingly taller:
Mclaren already do this, (using a "centerline cooling system" i.e moving as many coolers from the sidepods to the engine cover). Almost all teams do now.That said, the huge intake in that area, suggested me something: maybe to make the largest possible room for the venturi underbody with 2022 regulations, it could be wise to move some of the coolings under the engine cover
The Alpine is a very special case. Not the best reference. The reason they had an elephant engine cover is more complicated.Renault already did with their 'elephant' bodywork last year... would that be a possible pattern for this season's cars?
Yes i have seen the internal ducts inside the Alpine engine cover. I guess they choose that layout also to try to have narrower sidepods, they seemed to me a little less wider than others when seen from above or in front view. We'll seeBlackout wrote: ↑10 Jan 2022, 18:13It's conceptually more similar to the 2021 MCL airscoop, which is inspired by the Merc airscoop. Merc was one of the first teams to use this specific design (2016), the triangle inside an ellipse... the triangle being the real metallic roll-hoop, while the ellipse is carbon fiber bodywork. The triangle feeding the engine, while the half circles feed the radiators.
And all their customers followed this design.
.I was referring more to the large oval-rounded shape which in my opinion is more similar to the Toro Rosso of 2017 (yes, clearly inspired by the W07, at the time...) but maybe we need to see the full layout... it could be an optical effect of the particular picture McLaren released.SmallSoldier wrote: ↑08 Jan 2022, 00:11Roll hoop slimmer than in the MCL35M and seemingly taller:
https://uploads.tapatalk-cdn.com/202201 ... 29ed48.jpg
viewtopic.php?p=1023935#p1023935
Yes i do know that, of course... i was just suggesting that maybe we will see an enhancement of this choice due to aero-reasons
.The Alpine is a very special case. Not the best reference. The reason they had an elephant engine cover is more complicated.Renault already did with their 'elephant' bodywork last year... would that be a possible pattern for this season's cars?
But this trend will continue for sure.
This may be the only choice for all teams as the new wheels have become larger and heavier, then the damping elements that serve them also increase in size, it is possible to place these elements in the top simply will not work or it will be extremely unprofitable due to the large weight.Emag wrote: ↑11 Jan 2022, 11:41A fairly reliable source has confirmed that Ferrari has gone with a pull rod front suspension as well.
Since both Ferrari and McLaren have seemingly found the same solution, one has to assume it will probably be a popular choice next year.
Nevertheless, I am still somewhat nervous about this choice. Last time McLaren had a pull rod front suspension (2013), things did not go so well.
That is the only way that I can see it being practical to go for pull-rods, placing the springs/dampers in the new ‘keel’ section.FW17 wrote: ↑11 Jan 2022, 11:49As people are discussing the front suspension as a pull rod system, will there be benifit of placing the entire system closer to the middle cockpit bulkhead rather than the front bulkhead?
We see at the rears where the rod is brought forward almost beyond the rear wheel line, so can the same be done at front bring it to where the cockpit rises?
Won't there be even more benifit of placing it even lower in terms of CG?
https://i.imgur.com/9sYXbGa.png
