Belatti wrote:To keep pressure constant would not be easier to put pressure relief valve?
Because a pressure relief valve would keep constant pressure by releasing some of the tire air to the atmosphere... but then if you have to slow down such as in the case of a Safety car both the temperature and pressure go below optimal operating perameters... the pressure goes even lower because you lowered the amount of air in the tire via the pressure realease valve, thus making it even more difficult to get the tire back up to temp & pressure.
Now if they link the pressure relief valve to a remote reservoir like many shock systems do currently, and feed the air back into the tire it would work, but this increases the complexity of the system several fold, and adds to overall weight.
