thanks for the diagram, i'm trying to sum up every bodywork paragraph and its implication.
For the moment i'm struggling a bit with the 3.8.4 rule and whether it bans ramp wings or not (i think that i does it indeed).
If someone has a drawing of an actual F1 cars with correct dimensions that would help!
I would need a 3 view one (top, side, bottom).
So far i came with this, please correct if you think i'm wrong:
F2009 regs sum up:
Overall
-Width stays the same than in 2008 (1800mm max, 1400mm bodywork)(3.3)
-Max height 950mm (3.6)
Front
-Bridge wings/ferrari wings banned but 2005 renault style upper plans authorized (3.7.3-4,3.7.
-Standard part for the front wing's lower central element, 50cm wide, no flaps authorized (3.7.3)
-Limited (minimum and maximum) surface for the front wing lower element 20 000 mm² (3.7.4-3.7.7)
-Front wing maw width 1800mm (3.7.6)
-cockpit to nose minimum height lowered to 75mm max 125mm (front wing included) (3.7.1)
-No boomerang/ear/vikings wings (3.11.1,3.11.2)
-hole nose permitted? (3.11.x, 3.8.x)
-Nose width may be extended/front wing bring forward (3.14.2,3.17.x)
-The adjustable part be the lower element of front wing starting from the outer edge of the standard part to the end plates. (2 adjustments per lap max 6°, except while at the pits) (3.18)
Between wheels
-No appendices authorized (chimneys, flips up, ramp wings, etc..) (3.8.1,3.8.4,3.8.5,3.9.1)
-Minimum sidepods radius fixed at 75mm from rear wheel center line through the cockpit, applies for bodywork 100mm above the reference plane (3.8.4)
-Sidepods lengthen till cockpit (3.8.4)
-Barge boards cut dimensions (3.8.4)
-sidepods height limited to 600mm (decreasing as you move towards rear wheels) (3.8.3,3.9.1)
-No apertures authorized in the sidepods except: exhaust parts and suspension travel members (3.8.4,3.8.5)
-Shark fins authorized (3.8.x,3.9.x)
-ramp wings banned (3.8.4)
Rear
-Bodywork less than 200mm above the reference plane, 1000 mm wide (3.5.1)
-Rear wings 750mm wide (3.5.2) up to 950mm high (3.6, no article limiting the rear wing height)
-No rear wing (main elements) below 730mm above reference plane (3.9.2)
-Beam wing no less than 300mm above the reference plane(3.10.1)
-Beam wing must be one element max (3.10.1)
-Rear wing must be 350mm behind wheels center line at maximum (3.10.2)
-Rear wing must be two element max (3.10.2)
-Minimum vertical spacing between beam wing and rear wing (3.10.8 )
-Diffuser moved rearwards by 330mm (from rear wheel center line to 300mm behind it)(3.12.1)
-Lateral diffuser height may be less than 50mm (3.12.2)
-Diffuser height raised to 175mm (3.12.7)
Some questions:
-I do not find anything preventing from using a hole in the nose
-I see nothing about the length of the diffuser(compared to the 2008 one)
-Nothing seems to prevent from using shark fins
