Don't most cars come with one of these already? And I imagine that something like the 24V cordless drill LiPo batteries may be a simple solution.WhiteBlue wrote:My marketing nose tells me that this is a killer app unless there are hidden show stoppers. If this is seriously developed it could have a very significant impact on all automotive drive trains in the future. You avoid almost all fundamental problems of chemical batteries. Anything remotely competitive in the chemical field has a usefull life of 1000 full load cycles and less than 80% thermal efficiency. The only disadvantage of this thing is the need for a starter battery.
So, if you hooked a low HP motor (7000rpm) to this and had a 10:1 gear, you could use it as a gas powered electric generator?WhiteBlue wrote:Check out the Williams web site for their new comany on KERS. It has a very informative grafic of the system.pipex wrote:Hi scarbs, do you have any information about the Williams KERS?
From what i know it uses a flywheel as a replacement for the batteries, and the system is electrical.
Thanks
http://www.williamshybridpower.com/technology/
There is also a very interesting Flash video of the F1 system.
In constrast these Lithium Batteries are going to be a nightmare in terms of management needs. Imagine to manage the loading of 60 cells individually. Apple does that for 8 cells in their most advanced computer. On top you have to manage the loading and unloading of the brake torque very carefully to avoid irritating the drivers.Bob Bell wrote:Q: Will you have the same specification battery for each race ?
Bell: ''The charging cycle will vary from race-to-race when it's on the car but we're not doing different batteries for different circuits. We are having a logistical nightmare just making the one type of battery. Having several different versions certified would be a nightmare.''
''One of the biggest challenges is to intelligently monitor the charging and cycles throughout the battery life, where all of the cells – 60-odd of them – are all in the same state of charge. It's dangerous if you have one abnormally low or high. The electronics to monitor and control all that is an important part of it.''
No, I would challenge that train of thoughts. The Flywheel has exactly the same function as the battery in the other cars. The rest of the system is the same except for minute details. And the Williams solution is the lightest. It follows that flywheels are lighter than batteries. And being almost exclusively made from carbon fiber composites they must be lighter than fuel tanks.ISLAMATRON wrote:but by that line of thinking the flywheel has to be more dense than the fuel, so it would be more advantageous to put the flywheel below the fuel tank, plus the gyroscopic moment made by the flywheel would be less effective the closer it is to the Cog no?
I remember reading somewhere in another forum (Atlas??, AFCA??) that Honda (RIP) was connecting to the gearbox too. The post said that Xtrac integrated the system in the gearbox casing, but i don't now if it was internally connected or it was only to hold the motor in place, dunno.ISLAMATRON wrote:Are they the only team connecting the motor/generator to the gearbox?
YEs the flywheel has the same function as the batteries but(BIG BUT HERE)the batteries can be placed nearly anywhere ballast formaly was and the flywheel cannot. The Batteries can almost be seen as ballast with the ability to store energy. The flywheel has certain size and shape whereas the battery pack can be designed to be almost any shape. With that said the entire flywheel component is not carbon fiber, the casing must be made of steel or possibly titanium, which is much denser than the fuel so ideally it should be placed as low as possible. And this says nothing of the gyroscopic moments acting on the chassis which are magnefied as the force is placed farther from the CoG.WhiteBlue wrote:No, I would challenge that train of thoughts. The Flywheel has exactly the same function as the battery in the other cars. The rest of the system is the same except for minute details. And the Williams solution is the lightest. It follows that flywheels are lighter than batteries. And being almost exclusively made from carbon fiber composites they must be lighter than fuel tanks.ISLAMATRON wrote:but by that line of thinking the flywheel has to be more dense than the fuel, so it would be more advantageous to put the flywheel below the fuel tank, plus the gyroscopic moment made by the flywheel would be less effective the closer it is to the Cog no?
Williams Hybrid wrote:No, we make sure that the containment of the flywheel is specified to withstand the worst case failure, including burst. With the flywheel being 100% composite, with no rotating metallic components or magnets at a high radius (the flywheel has a steel central shaft), this means that the maximum failure load which the containment has to withstand is the crushing force of the carbon fibre, and not the load of a failed metallic disc travelling at high speed. See Safety Section for further details
