Nice thought
Belatti, Fastest one of these cars has ever gone is about 53mph, it had a voltage boosting(batteries run flatter much quicker) speed contoller and was back in the days of the fully enclosed car.
Tomba, on reflection I may just be able to round off the nose a bit, that it is just made of foam and bodyfiller... think we've got some more flourescent paint. It only goes as high as the black "aero tape" in the picture, I suspect that'd releave the pressure on the sides a bit,
Slimjim if your out there any chance you could apply a round to that front part?
Flyn I agree with your comment, the idea is not so much to force air anywhere, the body sagged a lot and will be higher next time which should allow some air flow a bit more freely and cope with the pressure of the perhaps somewhat over the top round on the leading edge.
I've kept the underneath dead smooth, only 5 gutter bolt style flat heads stick out underneath. Ground clearance as mentioned had sagged to around 25mm(lowest point on body) a bit of work should see it nearer 60mm
Interesting you mention NACA Profiles, I looked at those but to fit them round the vehicle meant massive frontal area, probably not as bad in profile rather than plan but still big, what's your view on FA vs. shape? I think we have one of the narrowest wheels fully enclosed cars at 680mm wide.
Fairing the helmet is tricky, very easy to cause a great deal of drag but something im looking in to. Roll bar should be faired for it's next outing.
Ciro really great contribution, thanks, it's nice to see something really constructive
This is (very roughly) what i'm thinking at the moment as a starting point, but im really interested in what people think would make the ideal shape.
I can provide some basic measurements if people want to have a crack at designing and the regs are found here
http://www.greenpower.co.uk/racing/rule ... us.php?a=1
Thank you soo much, all of you it's really appreciated
