The question is then ,why start on primes when they won´t last any longer than option.the tyres keep being a mystery this year more than in 2009.
Yea it's really a myth for my why most of the teams started on hard tires last GP.
Even the commentators all agreed that McLaren will fail because they started on soft ones.
Well I think the opposite is true.
When you have a good and a bad tire you should start the race with the bad one.
Especially when you are leading the race and therefore set the pace for the following cars.
With the soft tire:
1. you are better in qualy
2. you are better at the start
3. a safety car is more likely at the start of the race so you can get rid of the shitty tire in a easy fashion
4. when the tire starts to get worn out the following cars can't use their tires because they have to follow you.
5. when you can't hold up the other cars any longer you go to pit, after that you have fresh hard tires and an advantage against the used ones of your competitors
6.when there is a safety car later in the race, the gap to the other cars is closed but they still have to pit and take the bad tires.
7. how should your competitors fight against you in the end of the race when their tires are slower after some laps?
I guess the teams hopped the soft tire will improve at the end when there is more rubber on track but obviously this effect is not big enough.
